I useing a wireless router and im trying to play games online with xbox..it keeps asking for my ip address when i put it in it keeps saying ip failed ?
  • 876 Answers
What is your computer model? try their solutions, which should be available on your hard. they probably have a diagnostic area to help you. Not knowing more bout your system, that is about the best advice I can give you. I have a dell and also dell diagnostics which helps with problems like this. It is probably a settings problem so that your router is not properly recognizing your PC.
Posted on Jul 31, 2008
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
(2) xbox 360's in same home; 1 wireless adapter, other ethernet
you need to assign a static ip address to each inside your router they are more than likely using the same ip address
Jul 02, 2009 | Microsoft Wireless Network Adapter Xbox...
IP address
I had the same problem with my Xbox and Netgear DG834 v4 (wired) router. I bought a Belkin F5D7632 wireless router and that did not work either. I then bought an Xbox wireless adapter and it connected ok. I do not know why the wired connection does not work. The cable length is 10m.
Dec 30, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Ip addresses
the wireless adapter is when you have a wireless router,take off the adapter and plug the ethernet cord from the modem to your xbox
Jul 13, 2008 | Microsoft Xbox 360 Console
IP Address keeps failing on my Xbox 360
You shouldnt have an amp, when you do this. Also, you arent supposed to plug the modem directly into the console. It is supposed to be plugged into a router, which is pluged into a computer. That was, you can configure it.
Apr 04, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Having problems connecting with friends when playing xbox live
Okay I didn't read every post but here is what you need to fix the dreaded BS on not being able to connect to friends.....The DMZ on your wireless router needs to be enabled and the IP address of your DMZ needs to be that of your Xbox 360. Go on your settings in your xbox and go under network settings and look at the IP address, put that exact IP address in your DMZ address setting on your wireless router settings. Make sure its enabled and the IP address is EXACTLY what it says on your xbox network settings. That should solve it all. That bypasses all your security for the xbox. Might want to put the UPNP on enable too. So the DMZ and the UPNP are both settings on your wireless router. If you have linksys its 192.168.1.1 or the linksys voice 192.168.15.1...... Try them both in your address bar, of course one at a time and DO NOT PUT www. JUST PUT 192.168.1.1 or 192.168.15.1 It should pull up a password screen and both username and pw are admin if you did not already change them. If you don't have linksys then just go online and find out how to change the settings on the router u have. This should solve it all and get you back online and rocking and rolling. Now you must do the same with your PS3 if you are having the same problems. Give me feedback on if it works. You can hit me up on xbox at BKM80. Good luck
Feb 15, 2008 | Microsoft Xbox 360 Console
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
