Question about Dishwashers
Dishes not clean especially on top shelf - Dishwashers
    Sergeant:
  • 225 Answers
Check the rotating spray bar - the little holes that the water comes out of - and which make it rotate - could well be clogged up with food debris and jar labels. It may be held on with a thmbwheel / knurled nut which may have a left hand thread.
Hope this helps. D.
Posted on Jul 31, 2008
lancer721
  • 229 Answers
SOURCE: My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Posted on Jan 18, 2009
  • 188 Answers
SOURCE: how do i remove cover on food chopper? kenmore 665
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
Posted on Feb 22, 2009
  • 323 Answers
SOURCE: MY KITCHENAID DISH WASHER TOP SHELF IS NOT CLEANING AT ALL .
There may be something plugging up the arm that sprays over the dishes. And of course, I'm sure you know not to place items like bowls, pots, etc that will block the flow of water from the bottom sprays.
Although the bottom jets do most of the working cleaning the top items, the spray from above is vital. Take the stem pipe leadin from the top to the bottom off and separate the spray arms carefully. If you can, look throgh each end to make sure no deposits are in there.
Another way is to blow compressed air from the center stem down in the water supply unit. If food particles are there you'll see them.
Posted on May 29, 2009
heatman101
  • 43501 Answers
SOURCE: dirt on dishes
Here is a tip that will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
SOURCE: I have just moved into a new rental & the
That looks like the Washing powder residue. I am having a similar problem. But I am finding that the heating element isn't working anymore and hence can't rinse with hot water thus appears the soapy residue which dries into a 'sandy' substance as you say. Sorry no solution for you yet, can you check if when it finishes and you open it - its still hot inside?
Posted on Oct 08, 2010
Why has It started groaning?
Check whether the top spray bar is catching on the dishes or on the drawer itself, check the free rotation of the spray bar.
Apr 14, 2016 | LG Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
The top shelf of dishes in my CDA dishwasher isn't coming out clean any more
Look at you manual. How to remove the top spryer to clean it, re-install and presto. (I hope)
Jan 13, 2013 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes come out dirty especially those on top shelf and a scum remains along the bottom of the dishwaher at the edge of the door i do use very hot water and a rinse agent
It sounds like you have a hard water issue. Please try dishwasher magic additive this will clean out the dishwasher and help you get better results.
Thanks
Dec 11, 2010 | Dishwashers
Items on top shelf are not getting clean whereas bottom shelf dishes are clean
I had this problem, and on mine it was because when I pushed the top shelf in , the little sleeve for the spinning nozzle wasn't fitting over the coupling that supplies water to it. Try checking the alignment when you push in the top shelf.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishwashers Logo
227 people viewed this question
Top Dishwashers Experts
