Question about Apple iPod mini M9160LL/A MP3 Player
My iPod Mini 1.4.1 (old version) won't shut down
It won't shut down properly can someone help?
I press the play and pause button it goes off - i tap the menu and it comes up immediately - this is draining the battery.
I have pressed the middle button and menu together to reset\ restored from through PC I Tunes. Nothing.
I would be grateful for any solution.
Thanks Narinder
  • 19 Answers
SOURCE: ipod nano
switch the hold button on and off, then hold horizontally, and push the menu button and center button at the same time. hold them down untill the ipod restarts and the apple logo apears. If that doesen't work, plug into the newest itunes program, and push restore.
Posted on May 02, 2007
ctf1800
  • 4402 Answers
SOURCE: 30 GB Ipod not shutting down
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Posted on Dec 21, 2007
  • 34 Answers
SOURCE: ipod touch with the backlight
you most likely have a hard ware problem which i have heard of before and most likely will need to be replaced as long as it is in warranty
Posted on Jan 25, 2009
GadgetRaja
  • 150 Answers
SOURCE: Ipod touch freezes on startup!
i) Hold “Power” button for 2 seconds
ii)Then while holding the Power button, you will now have to hold Home button too for 10 seconds.
iii)Then release Power button but keep holding Home button for about 30 seconds
it should take you to Restore mode .. now connect yo
Posted on Sep 02, 2009
GadgetRaja
  • 150 Answers
SOURCE: my iPod's center button doesnt work
take to service center , why you wanna buy new ?? they would replace your ipod if you got warranty else repair it
http://www.apple.com/support/ipod/service/faq/
Posted on Sep 03, 2009
Testimonial: "thanks i'll try it"
30gb ipod freeze up cant shutdown to reboot
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 14, 2013 | Apple iPod Audio Players & Recorders
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
My ipod Nano wont shut off properly. I hold the play/pause button down for 10+ secs but it still doesn't shut off properly; when i press another button it immediately starts back up. What am I doing wrong?
As far as I understand the nano it does not switch off it goes to sleep which is a low power mode so don't worry but when you put it to sleep remember and put the hold button on and that will stop it from waking up and using power. Hope this helps
Nov 02, 2009 | Audio Players & Recorders
My Apple iPod Mini won't play or connect to the PC. It displays the charging symbol but isn't recognised by any PC. It also displays the sad face once charged, and then 'do not disconnect' sometimes. I've...
Yes you must do a reset.
Turn the lock switch off.
Hold down the centre button.
Press and hold down menu.
When the Apple logo appears let both buttons go.
Should then work properly.
Jun 28, 2009 | Apple iPod mini 2nd generation MP3 Player
My computer won't recognize my nano ipod. When I first plugged it in a message appeared and said the install did not install completely and it may not work properly. Now the apple logo is on the ipod but...
I would recommend forcing the ipod into disc mode and then reconnecting to your computer to restore it using iTunes. Below is a step by step on my recommended solution just in case you need the information.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jun 24, 2009 | Apple iPod MA446LL/A MP3 Player
Having problems when connecting ipod to my computer
Have you already attempted to force the iPod into disc mode before connecting the iPod to your computer? If not I would recommend doing now. If you can get the iPod to connect to your computer at this point you will want to restore it using the latest version of iTunes.
May 28, 2009 | Apple iPod MA446LL/A MP3 Player
I have an 80gb iPod Video, and it hangs up on the Apple logo. It won't show up on iTunes for 64bit Vista, the latest version, and only sometimes on my PC, OS Vista 64bit. Resetting it, restoring, and...
Silly question, have you tried the ipod on someone else's computer to ensure that it is for sure the ipod?
It does sound to me like your hard drive in the ipod has crashed. I would still try it though. I would even try putting it into disc mode while it is connected to power to see if that will work. If it does go into disc mode, restore it as before and let it charge over night or for about six to eight hours. Then after that if it still does not work while not connected to power you simply need a new battery. If not its the hard drive. Below i've posted a step by step on putting an ipod into disc mode just in case you need it. :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
I do hope that this is helpful to you and that your issue is resolved easily. :)
Apr 30, 2009 | Apple iPod MA446LL/A MP3 Player
How do I shut off my zune!?!?
hi,
keep pressing the play button for 10seconds. it must shut off.
thanks you
Feb 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
Ipod won't turn off
You may want to try an earlier version of the firmware. You can actually download the older firmware for that one from Apple and in iTunes hold the shift key before you click restore. That will allow you to select the file of the firmware version you want instead of the newest version it defaults to. You won't have to reinstall an older version of iTunes that way.
If it doesn't turn off when you pause it you can also press and hold the play pause button after it is paused to force a power down. I doubt that it us a battery issue and replacing it won't help. If you do decide to replace the battery you can get a battery from various web sites for 10-30 dollars that come with the opener tool and you can replace it yourself for cheap.
Cheers and best wishes.
Dec 04, 2008 | Apple iPod nano 2nd Generation MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
259 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
