Hello PMewis, Just a clarifitication question about your printer. You installed directly off the HP install cd. Is the message your getting related to when you try to scan from the deskjet itself, or is it when you try and use the hp software.
This will help in trying to determine where to figure out where the problem is, also what operating system are you using and what version. (Windows/Linux/Apple - XP/Vista/Win7)Hello PMewis, Just a clarifitication question about your printer. You installed directly off the HP install cd. Is the message your getting related to when you try to scan from the deskjet itself, or is it when you try and use the hp software.
You can't post conmments that contain an email address.
1.Uninstall the installed driver first.
2.Disconnect Data cable from CPU.
3.Then connect the printer with CPU.
4.Turn on the printer.
5.If the PC detect the printer, install it.otherwise check the data cable or ports are ok or not.
Open the lid of your scanner and press the copy button do you see any light moving below the glass .. if no then its a hardware issue contact HP for service
In the scanning software of the printer there is an option to select PDF as your default.
Please go into the scanning software feature located in the program menu.
You will have to reinstall the printer/scanner drivers (check on the internet for your type/model and download the drivers if you can't find the original install cd). Usually the HP website is your best bet for old or new driver sets. Source(s): http://h10025.www1.hp.com/ewfrf/wc/produ? Hope it works.
Perform the steps below to restart the spooler.. this will clean the print queue.
(1) Click "Start" > "Run". (2) Type "services.msc". (3) Click "OK". (A window will pop-up with so many services listed) (4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu. (5) Now please restart the computer.
if the issue still persists, i would like to know what exactly are you trying to do... * Printing a picture * Scanning a picture
the software was not completely installed, that's why. do a complete uninstallation first of the said program/software driver and then restart computer, then do a complete installation this time.
there is a program called infranview. Download it and use that program. Awesome scanner program.
As soon as you installed it
open it
goto file
and than aquire batch/scanning
