Question about Lexmark Office Equipment & Supplies
Printer getting power phone lines working wi fi device lit. Printer power not lit and printer not working
Returned to manufacture
Posted on Aug 01, 2008
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
My pixma mg 3250 worked yesterday turned off the power last night and now won't communicate with phone.
Has someone turned off wi fi or Bluetooth on the phone? Are there any error codes showing on the printer? Check Wifi settings on the printer too.
May 25, 2015 | Cell Phones
How do I print from my Samsung Galaxy Pocket S5300 to a Brothers Printer HL- 2130
hL-2130 is not a wireless or network printer. So it is unlikely you will be able to print directly from the S5300 even if you get a Samsung wi-fi print app. You can however, try to use services like Printer share which can allow you to configure your computer connected to the printer to be used as a printer client to service wi-fi printing from your mobile phone.
http://www.printershare.com/help-mobile-printertypes.sdf
Apr 27, 2014 | Samsung Galaxy Cell Phones
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
NO ACCESS TO WI-FI
u can also check power setting, it might be on "power save mode"
Jun 04, 2013 | Kocaso M1052S 10.1" Android 4.0 Tablet PC
Lexmark Pro 915 wireless print problem
Try set a static IP on your printer. Check the steps in this article: http://bit.ly/SxORCU.
After setting a static IP, set the network port to the IP address that you provided to your printer or you can reinstall the drivers.
Jul 27, 2012 | Lexmark Pro 915 All-in-one Printer W/inks...
It will not print my document, but will print test pages, from the internet and from other programs. It gives me a message that I need to install my printer (which I did again) but it says there is none...
1. Have we made sure the printer cable is connected to the computer? The cable is sold separately from the printer, generally speaking it is a USB cable. (In most cases this cable needs to be plugged in to the computer and the printer needs to be powered on when running the printer installation software)
2. Of the printer is a Wi-Fi printer you will first need to make sure that you join the printer to the same Wi-Fi network that your computer is joined to.
3. Sometimes even if you have a Wi-Fi printer the manufacturer will require you to connect the printer to the computer just the first time, it gathers information about this Wi-Fi network from the computer and then passes the information to the printer.
4. I have also noticed that in some cases steps all or some of steps 1-3 need to be completed for internet printing to work.
Nov 08, 2011 | Corel WordPerfect Office 12 Home Edition...
Hp printer
This is what Maggix reported to solve the problem:
"I have found with this printer that the issue is a mis configured Wi-Fi card. Not sure how to fix it so you have wi-fi but if thats not an issue you can unplug the wi-fi card and it will boot and work again. To do this take the back panel off, there will be a bunch of ribbon connectors and plastic wire connectors. There will be one plastic connector set that has 5 or 6 wires and is wrapped in a black sheath. unplug this it is the wi-fi card. plug the machine back in and see if it boots right."
I tried and it works for me. The cable is located in the upper area of the small board on the back of the printer. It's a ribbon cable made of 5-6 coloured wires, all tied together with a black wrap.
Hope it helps
Sep 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Oct 10, 2007 | i-mate K-jam Smartphone
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
