Question about Hoover AAA140 Front Load Washer
Buying rear drum bearing on hoover AAA140
The drum bearing is noisy. I have been to simco to try and purchase a replacement bearing but they only seam to be able to get hold of a whole rear tub assembly at £180 (40004223).
They only do a bearing seal £16 (09028960).
Does anyone know where I can buy just the bearing or know the size of it so that I can purchase one locally. (prefer not to have to remove it first to find out !)
I also notice the brushes I have purchased are wrong!
Thanks very much
  • Hoover Master
  • 3,463 Answers
Hi.
If you put oover in your web browser, click on laundry, you will be given different options, you will eventually get to spares and a enquiry section.
You shouold then be able to find what you require.
Posted on Nov 22, 2008
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Hoover condenser dryer, drum is stiking, if i manually spin the drum ir will go bk in cycle
see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Dryers
Hoover nextra washing machine model hnl 6166. how do i replace noisy drum bearings
If you are mecahical inclined look up the model and seriael
# on the web. ask them to send you a book of maitence on it and this should show you how and where the bearings are and where to get new and how to replace them.
May 10, 2011 | Hoover Washing Machines
Eo5 keeps coming up
Indicates a fault with the heater or the thermistor (temp. sensor). Both located at the bottom rear of the drum.
Jan 14, 2011 | Hoover AAA140 Front Load Washer
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Noisy Servis M9503S
Hi.
Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
Nov 22, 2008 | Hoover AAA140 Front Load Washer
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Hoover AAA140 Front Load Washer Logo
133 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
