Question about Innovage Touch-panel Phone 1502084
Bob i cannot use the keyboard, is not responding. only the letter p in the screen. Only i receive calls. It lock mode or is a deterioration of the phone?
  • 32 Answers
Was thinkin the phone function IP might be on. it is not applicable in the USA, so make sure it is off. but that might be a little difficult if the keyboard isn't working. might be the phone is defective. my phone is model number 1507102 but if you think it might help to read the manual , i will send you a copy if you can email me. my email is all8upinwv@yahoo.com i'd be happy to send you a copy.
hope it helps.
tammy
Posted on Aug 12, 2008
Streambook 13 keyboard locked up. How to return it to original settings
since the laptop is only a few days old I would recommend performing a factory restore to the "out of box" state.
Jan 05, 2015 | HP Computers & Internet
My laptop screen is black, but I can tell the power is running. Cap lock lights will appear, is there something that disables the screen.
Normal power settings call for a power save mode. This will allow the hard drive to spin down, the monitor to go blank, but keeps the computer in STANDBY mode until there is an input from either the keyboard or the mouse.
Sometimes you have to hit the power button.
This setting can be modified in many ways.
right click on your desktop, select properties and select the screen saver tab, at the bottom is the power setting button. you can configure how you want your system to respond to your schedule.
Sep 27, 2010 | Computers & Internet
My Keyboard works normally when I type a document or letter. However when I try to type an e-mail or letter, the keys do not always respond correctly.HELP appreciated bob.stinchcombe1@btinternet.com I am...
check the language bar. It's most likely changing from your default language to a secondary language. Set your prefered language to default and if that doesn't help, try to uninstall your secondary language.
If you still need your secondary language you then have to reinstall it but it most often solves problems like this.
Mar 15, 2010 | Microsoft Windows XP Home Edition
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Just moved keyboard and mouse not responding.
If you have wireless keyboard mouse try standard ones and see if they work you may get it off power mode
Jul 31, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Letter between n and , also cap lock and # before 2 do not respond
This genarally indicates that the keyboard is going out. Try taking the keys off and making sure the rubber depressor is in the proper place in order to make a good contact with the key sensor. If they are then thekeyboard will need to be replaced.
Jul 11, 2008 | IBM ThinkPad R52 Notebook
Keyboard
Can you please clarify this
  1. Do you keys not respond at all
  2. Do you get numbers when you want letters or otherwise letters to numbers
  3. Or does it respond only in one mode numbers only or letters only
My suggestions
  1. If its situation 1 then try reastarting your machine, and unblocking the num lock and vice versa
  2. If its situation 2 just try unblocking num and blocking back by turning on or off the num lock, its just num lock or FN + Num lock in some PC
  3. If its situation 3 just restart your computer.
Mar 25, 2008 | Acer TravelMate 361EV PC Notebook
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Innovage Touch-panel Phone 1502084 Logo
52 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
