Question about Dishwashers
GOT A KENWOOD KDW24F1/B DISHWASHER STUCK IN CYCLE ALARM BEEPING ALL 4 RED LIGHTS ON L/H SIDE OF PANEL ON PUMP WORKING , ANY IDEAS PAUL
  • 2 more comments
  • brucepow Oct 29, 2008
    Exactly the same problem
  • Anonymous Nov 16, 2008
    i have the same problem all 4 lights flashing
  • Anonymous Dec 22, 2008
    same snag
  • Anonymous Jan 14, 2009
    my dish washer is fucked how do i fix this ? lots of love bob from manchester
stephanos18
  • 144 Answers
SOURCE: dishwasher is stuck on the pump cycle trying to get rid of water
The machine is in flood protection mode. cheers
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
Posted on Aug 11, 2009
Testimonial: "true, bottom tray was wet fron small split in waste pipe taped it up and have ordered new one thanks for the info job well done"
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
charliech822
SOURCE: stops working half way through a cycle and alarm goes off
how many beeps does it make
Posted on Oct 04, 2009
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
Posted on Feb 16, 2010
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Dishwasher shows error e01
It seems like main motor pump or main control problem
do step by step troubleshooting procedure to eliminate working parts until you could detect defective part or parts
Dec 09, 2013 | Kenwood KDW243A Builtin Dishwasher
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
When i turn the dishwasher on it start but when it whant's to wash the two red lights goes on and machine beep and stop washing.
After the intital cycle of the water inlet vavle opening the program shifts to the next mode But since there is errors on the controller the machine shuts off with an alarm.
Now check the front door opening switches, check the washer pumps, check the drain cycle/pump.
remove and check the door switch contacts, the pump and the drain.
Jun 14, 2011 | Dishwashers
I have a kenwood dishwasher KDW24F1/B the left hand hinge has broken where can i get a replacement and could i fit it myself
Try repairClinic.com . They have a large selection of repair parts with detailed replacement installation instructions.
Jan 04, 2011 | Kenwood Dishwashers
Both drawers are stuck in the on position, both
The water sensor is malfunctioning. It believes that there is still water, so the pumps run and the washer will not continue on its cycle. replace the water sensor, or dry it out so it functions properly
May 15, 2010 | KitchenAid 23 in. KUDD01DPPA Stainless...
Siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Jun 01, 2008 | Dishwashers
Open Questions:
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
