USB Ports my LG LS 50 Laptop All USB do not working. How to fix it. Thanks for the help.
  • 2 more comments
  • Anonymous Jan 02, 2009
    I have Acer laptop problem is that my all four USB port are not detecting by my laptop.if anybody have solution plz mail me at naweenmca@gmail.com.
    Thanks
  • Anonymous Feb 12, 2009
    all of my usb port not work the power out fine from 3 ports but any of ports not work my model lg ls50
  • hzzam Feb 12, 2009
    i have asame problem in the same device lg ls50 the power out fine from ports of usb but its not working plz help me
  • biggraphics Mar 14, 2009
    If the system is up and I plug in the usb mouse, the Dell 1501 can not load the driver. However, If I simply reboot, it loads properly... what give on this? This happens with both a MS mouse and a brand new logitech mouse.
    Scholar:
  • 152 Answers
You have to enable your USB slots in the configuration settings menu.
Posted on Aug 29, 2008
    Scholar:
  • 93 Answers
If they wereworking before, then all of a sudden stopped, and you have not changed ANY configuration changes in the bios, or un-installed any service packs lately. first thing to do is make sure if using Windows XP, that AT LEAST Service pack 2 is installed. chances are either you have damaged one of the usb ports causing a short, and causes all the usb ports to stop functioning (seen it a few times),or windows has simply needs its USB drivers refreshed, which is very common
Click START
RIGHT click on my computer
Click Properties
select the HARDWARE taclick the DEVICE MANAGER button
a box will appear with a list of every component in the system, down the very bottom will be your USB ddevices, ensure none of them have a yellow exclamation mark, or question mark next to them, if so, RIGHT click on the component, click UNINSTALL, click ok to confirm, it will the dissapear, close device manager, restart the system, apon startup the system will recognise the USB controller as a new divice and automatically install drivers (they are built into windows), it should tell you once it is installed, and your USB should function.
if there are NO exclamation marks or quesion marks, do the same above procedure to remove the component, but do it for ALL COMPONENTS under the usb heading, and then restart the system, and let it auto detect and install drivers.
Posted on Nov 12, 2008
How recover bios password for lg laptop ls 50 a ?
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore...
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
Aug 04, 2014 | LG Computers & Internet
LG laptop usb ports not working
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
May 07, 2012 | Computers & Internet
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Please tell me what wrong with my WD passport, it work normal when i connected it to computer, but when it is connected to laptop, it does not work, it does not get any power (no light indicated). Thanks
USB ports carry electricity, as well as data.
While the USB ports on your desktop are OK, the USB ports on your laptop are not sending enough voltage/amperage to power your device.
There exist 'Y-cables' that connect to TWO USB ports on the laptop, and draw power from BOTH ports, to push more power to the device. Try such a cable.
Oct 28, 2010 | Western Digital WD Passport 250GB Portable...
USB PORT NOT WORKING.
Both USB ports use the same driver, so if one works and one doesn't, you have a mechanically bad port. You'll need to replace the hardware to solve the problem. There are usually a lot of bad D600 motherboards on Ebay. Or try to find just the USB port you need. Fairly simple replacement task, but laptop dis-assembly will be required to reach the part.
Nov 12, 2009 | Dell Latitude D600 Notebook
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
KG 800 Annoying Problem,
If u want to transfer some data in your mobile,
when u plug in usb in your mobile and laptop u got 2 sms on u r mobile , mass storage, com port
you select mass storage, suddenly your mobile re-start ,than u got USB on on ur mobile
On other side on your laptop ,open my computer than u find removeable device.From there u can able to sync
If u want to connect to internet than download LG INTERNET KIT from wow lg.com
Nov 11, 2007 | LG KG800 Cellular Phone
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
