For this issue, you may need to manually search for a network if there's a sim card inside it. Or go to the network options on that phone turn off offline mode. I hope this helps a bit
It's because of Network Lock,It locked to Vodafone Network,You need to Unlock it to work in other Network,You can get the Unlock code and instructions at here http://www.onlinegsmunlock.com/nokia-e63/rs7wp9/ and Unlock it.
(1) Pl z go on profile mode and here activate a general profile OK
(2) when u open a fone here a msg appear on your fone dat start" fone in offline mode" then u press a NO ok.
step 1>switch off your phone and turn it on again step2>you should get a respond <: continue in offline mode>: select no finally, i believe that everything should be ok. if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ? my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape 2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card. 3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
