I own a teac hdb840 set top box which is hooked up to a rear projector tv.the set top box and the tv support 480p,576p,1080i resolution.why do i only get 576p resolution on my tv?
  • taajan Aug 04, 2008
    my tv supports 480p/1080i at 60hz and 576p at 50hz
    set top box supports 480p/576p/1080i but i dont know its output frequency.why do i only get 576p resolution
    on the monitor?
    settop box:HDB840
    TV:PHILIPS 55" REAR PROJECTOR
  • taajan Aug 06, 2008
    i have changed cable to VGA(input/output),but still get 576p resolution on the monitor.i am using an analoge terestrial antenna.does this make a difference in the signal strenght into the set top box?
    Genius:
  • 2,035 Answers
Your set top box is using standard resolution which is 576p you need to change the resolution on the menu of the tv set top box:
Good luck..
Posted on Aug 06, 2008
    Sergeant:
    Champion:
  • 221 Answers
Your TV & S T B support the higher resolution you're not getting definitely is a Hardware Problem. To diagnose whether this problem belongs to either of TV or S T B, try connecting your TV to another Set Top Box and if it solves the problem, your S T B (Set Top Box) has malfunctioned and you need hand it over to the Service Center for repairs or replacement. If the problem persists even with the other S T B, your TV needs Service Center.
    Genius:
  • 1,665 Answers
See if you can select high definition mode for your set top box.
Features
􀂃 HD Digital Set Top Box Receiver
􀂃 Produces high quality, crystal clear images
􀂃 Stylish front panel design
􀂃 HDMI Digital Signal for high quality video
􀂃 Decodes all High Definition modes – 576p,
720p, 1080i
􀂃 Decodes Standard Definition Signals – 576i
􀂃 Aspect ratio: 4:3 and 16:9 selectable.
􀂃 Favourite channel editor
􀂃 Teletext & Closed Captioning
􀂃 Full Function Remote Control
􀂃 Electronic Program Guide
􀂃 Stylish, easy menu system
Specifications
􀂃 HDMI output
􀂃 Component Video Out (Y/Pb/Pr)
􀂃 S-video output
􀂃 Composite output
􀂃 S/PDIF: Digital Audio Optical Output
􀂃 12 Month Warranty
􀂃 APN: 9325073011311
link
Posted on Aug 04, 2008
  • 928 Answers
There are instances that the input cable from a settop box is unable to output a clear enough signal to the projector which is why the projector will switch over to a lower resolution that it can display. Check your cable as well as recheck your settings on the TV and settop box again. But do make sure that you check if your cable is good enough. An option would be to try it on another system if possible.
  • 2,071 Answers
Review your resolution setting and maybe there miss the set up..
Posted on Aug 03, 2008
The tv works with the antenna and the ski but turned it self off after about an hour when I watched my bluray player and the red light came on. After a couple of minutes I was able to turn back on but...
Go into the setup of your Bluray player and in Video setup reduce the resolution to 720p from the default setting of 1080p.
Some Bluray players have a button on the remote labeled HDMI. Every time you press this button the output resolution will change from 480p / 576p / 720p /1080i /1080p. Try one of the lower resolution that way it will strain your TV's graphic processor a little less.
Mar 10, 2011 | Mitsubishi WD-57733 57" HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
