Question about Refrigerators
Subject: 'New' Kenmore bottom freezer refrigerator door dispensor error code. Fridge+freezer work, however, digital display has following error code: "Er......1F" where "Frz Temp+Ref Temp" displays are located. Unplugging+plugging power cord resets and it works for just a few minutes before going back to error codes. That stops water/ice maker from working also. Fridge is only a few months old. 1st time for problem. Any help appreciated, thanks, regards, Mark. Note: (doors were removed/installed upon delivery to fit kitchen entrance).
  • Mark Pagano Mar 09, 2011
    Yes, just got off phone with Sears repair. Part will be replaced under warranty this Friday. (They are 'bending over backwards' to fix this 'new' fridge since I am a Sears Reward customer). Their technical dept. knew all about that specific code and should R+R the ice maker fan motor with no problem. Thanks! Regards, Mark.
  • 17,970 Answers
This is a bad fan motor (click here like a sample replacement) inside the back wall of the freezer, you will need to replace it with part number that could look it accroding with your model. You can order the parts you need from the following places:
- http://www.apwagner.com/
- http://www.repairclinic.com/
- http://www.searspartsdirect.com/
So, according with your comments, if your device has few months, before to take off some part, I suggest contact your dealer or technical service keeping under warranty service.
Hope this helps.
Posted on Mar 09, 2011
  • ZJ Limited
    ZJ Limited Mar 09, 2011
    That is where the error codes come up on an LG unit (quote), the computer is not seeing feedback from the fan, which has been a major problem since this unit has come out on the market, usually you can unplug the unit for 5 minutes and plug it back in, the error code may not come back for days,weeks or months, but it always comes back to the fan motor...
    I gave you the wrong part number this is the ice maker fan motor, sorry about that, the error is IF not 1F If it was the freezer fan the FF would come up, the correct part number is XXXXX (check sample here).
  • ZJ Limited
    Your welcome, thank you for using Fixya.
SOURCE:
ER CF error code on fridge
Sarah can you look in the refrigerator door or around the fresh food section door for a model number that looks like 106.78900 I need that number to be able to tell you what the error code is. Appliance 911 Sea Breeze
Nov 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite model # 795.77564600 refrigerator stops cooling; display on left side door reads ER FF
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Fridge - Getting ER F5 error on display
Er-FS error code: Failure of freezer sensor.
I have been finding the fuseable link in the defrost system on these models open preventing the defrost cycle.
This would involve removing the freezer back panel and removing the sensor and fuse from the evaporator.
It's just a plug in.
May 23, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
