Question about Samsung Digimax V800 Digital Camera
8GB SDHC Cards
Is a SanDisk 8GB SDHC compatable with a Samsung Digimax V800?
    Brigadier General:
  • 3,006 Answers
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Posted on Oct 06, 2010
Sandisk com wug
What model Samsung camera? Is it compatible with SDHC cards or only with SD cards?
Apr 24, 2013 | Transcend 8gb Sd Hc Sdhc 8 Gb 8g Class 6...
Check sd card
The V800 works with SD cards. Your new 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to go with SD cards, 2GB and smaller.
Feb 23, 2012 | Samsung Digimax V800 Digital Camera
What capacity SD card can I use in my Samsung Digimax V800, I was told only 1GB is this true. Thanks
The manual only guarantees cards up to 1GB. However, SD cards go up to 2GB and such cards should work. Cards larger than 2GB are SDHC and will NOT work.
Aug 06, 2011 | Samsung Digimax V800 Digital Camera
Is there a firmware update or any update that will allow me to use a 16gb SDHC card in my Samsung Digimax V800. If there is how do I install it
No. The differences between SD and SDHC goes beyond what firmware can change. It's possible to design a device to use both SD and SDHC cards, but a device that was only designed for SD cards cannot use SDHC cards without hardware changes.
May 29, 2011 | Samsung Digimax V800 Digital Camera
Recently bough a Lexar SDHC 8 GB memory card and now my Samsung Digimax A503 camera won't turn on with the card in. It will power up for about 15seconds and than shuts off. The camera works fine without...
Hi.
The 8GB memory card is too big. The Samsung Digimax A503 only supports SD cards up to 2GB and is probably the reason the camera is turning itself off.
Click on the link below to see for yourself.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Samsung/Samsung+Digimax+A503_Memory_Cards
Regards.
May 01, 2011 | Cameras
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
Mar 01, 2011 | Samsung Digimax A7 Digital Camera
Bought a new sony sd/sdhc memory card 8gb and it will not format/load for my camera--what do I need to do?
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 23, 2011 | Samsung Digimax D53 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Will a 8gb sdhc card work in a camera that has sd cards
Its depend upon your camera compatibility with memory card.Go to your cam brand company site and find your product.See the memory cards shown for it.
Feb 19, 2010 | Samsung Digimax D53 Digital Camera
SAMSUNG V800 SDHC CARD FIRMWARE UPGRADE
Feb 05, 2009 | Samsung Digimax V800 Digital Camera
Samsung Digimax V800 Digital Camera Logo
177 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
