Everything works but no ink deposited - Office Equipment & Supplies
    Sergeant:
  • 390 Answers
Many issues here. Is it refilled or new original. If refilled may be an air bubble, blow out refil hole or squirt more cour into holes to clear (can also carefully draw out a little ink and then clear syringe, then draw more ink and refill to correct bubble problem. I f new, your heads may need cleaning, dried ink deposots can clog printheads. Clean manually with cleaning solution or printers own program. cheers lilacgerry
Posted on Jul 31, 2008
When I power up the printer it lights the red led indicating problems with the ink cartridge i saw a video before thst helped me to solve this problem resetting the printer coulyou help me pls
replace the cartridges with replacement or re-sit the cartridges, and if not helping, uninstall everything and reinstall basck up everything , the whole packet
Apr 05, 2014 | Epson Stylus TX200 Series
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Mar 31, 2011 | Computers & Internet
I put new cartridges in my printer and now it will not print at all. I have tries everything, I am ready of uninstall the printer. What can I do? Karen
Take a tissue paper and and place the small flat metal part of the cartridge on it, If there is no clear deposit of ink on the tissue and you are quite sure there is ink in the cartridge, there is a possibility that the ink is dry, If possible inject an ink thinner into a small hole that leads into the cartridge duct to dilute the ink.
Mar 22, 2011 | Office Equipment & Supplies
Won't print
download smartpanel for this model from samsung web,install on pc,will tell you what the problem is.
May 31, 2009 | Samsung CLP 300 Laser Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Ink deposit on the bar below the cartridges
Hi Autofire,
Please click on the web link given below and try to clean the deposited ink with a soft cloth, you can also use petrol to clean the ink.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Mar 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
Ink spots on paper
yikes...calibration worked too? there may be some deposits on the head carriers, underneath the cartridges..
cue tip, with denatured alcohol(not Coors or Becks) might reveal some nasty crud in there.
Feb 27, 2008 | Epson Stylus C44UX InkJet Printer
S520 will not print in any color
If you have tried to print a nozzle check page and no ink has been deposited on the page, then it might be a bad logic board inside the printer or a faulty purge unit. Both parts are relatively expensive to purchase. You might be better off looking for a used Canon s520, i550, i850, pixma 3000, or similar model to use the remaining ink cartridges if you can locate one in good condition and not more than 40 USD. xcd187
Oct 03, 2007 | Canon S520 InkJet Photo Printer
123 people viewed this question
jasbo
jasbo
