Question about Microsoft Excel for PC
Sum of Alternative Columns
I have data in column A,B,C,D,E,F, i need total of A+C+E in G column and total of B+D+F in H column.
I know one formula i.e. on column G we input =A+C+E, then the total will come but I need an alternative formula for this, could you help me out in this issue, Advance Thanks, Harish
  • 10,594 Answers
Alternative Formula? please explain it.
Posted on Jul 31, 2008
Hi, My formula will not give me the correct sum when I drag it down into new columns even though the formula is correct. Please advise
What happens if you copy the formula from one cell and paste it into another? Sometimes formulas don't drag correctly. This can happen especially when you have more complex formulas. Another thing that can throw off the drag and drop copying of formulas are hidden rows or columns.
If a copy paste doesn't fix the issue than reply with the exact formula and a snippet of your data so I can troubleshoot it better.
Apr 04, 2017 | The Computers & Internet
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
Ms Access 2003
If Access is anything like Excel, you can put in one of the cells: =SUM(A1:A5) If I remember rightly. That will add all the values from A1 to A5 together and display it. Alternatively, you can do =SUM( and then select all the values you wish to add together with your mouse by dragging, or selecting individually by holding CTRL whilst individually selecting. Hope this helps, because I'm only going under the assumption that Access is similar to Excel. Either way, you will need to use a formula similar to the one I just showed you.
Sep 10, 2007 | Microsoft Office Standard for PC
I am trying to figure out a payroll formula. I
Here is how you could do the formula with two one column having the hours of each day in it and the overtime being in another cell:
Example:
Column A Column B
8
8
8
8
0
Total 40 OverTime 2
Formula in this cell where 40 is at:
=IF(SUM(A1:A7)>40,40,SUM(A1:A7))
Formula in cell where 2 is at:
=IF(A8>40,0,SUM(A1:A7)-A8)
Let me know if this helps.
Jan 01, 2010 | Microsoft Excel 2007 Home and Student...
How to get all balance sheet entries tally to excel
This is a very handy process when you're totaling or subtotaling columns. On the cell that you want the 'total' in type '=sum(column letter row number),(column letter row number). The first 'column letter row number' is where you want the first cell to be started in the total factor and the second 'column letter row number) is the last cell you want added in the total factor. The help (?) section is good at explaining formulas. Hope this helps, keep this process handy if you use Excel much because it'll be helpfull each time you subtotal or total columns.
Bob
Sep 23, 2009 | Computers & Internet
CAN GET COLUMNS TO ADD UP AND GIVE TOTAL ONLY GET SUBTOTALS
Use the function =sum() to add numbers. To sum, for example, all of column A, enter in the formula bar =sum($A:$A). You can use the subtotal function within the range you are adding and the answer will not count towards the final total.
Mar 14, 2009 | Microsoft Excel for PC
BASIC EXCEL FORMULA
Are you looking to solve any particular problem?--- because there are a huge number of possible formulas in Excel.
However, in my opinion, the most commonly needed ones are addition, subtraction, division, multiplication, and summing.
Suppose you have the following numbers typed into your Excel spreadsheet:
columns: A B C D
rows
1 20 3
2 10 4
3 15 2
4 1 2 3
Then suppose you type in the following formulas (in the D column):
columns: A B C D
rows
1 20 3 =A1+B1
2 10 4 =A2-B2
3 15 2 =A3*B2
4 1 2 3 =sum(A4:C4)
Then the following answers will appear in the D column:
columns: A B C D
rows
1 20 3 23
2 10 4 6
3 15 2 30
4 1 2 3 6
Sep 29, 2008 | Microsoft Computers & Internet
Excel formula
Assuming that all of your data is in a single row number 4 and between columns N and PF
Try:
{=OFFSET(N4,0,MATCH(TODAY(),N4:PF4,0)+1,1,1)}
The MATCH function looks up the value of today() in the range N4 to PF4 and returns the number of columns offset from the beginning of the range. (The 0 here does an exact match)
The OFFSET function returns a value from a cell a specified number of columns from a reference cell, in this case N4, which is the first column that contains the search data. We need to add on to this value to skip the Interest column.
Regards,
Daryl
Jan 25, 2008 | Computers & Internet
Formula required
at first select the 1st page data and select data-subtotal from the upper menu list.
then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
If not solved pls get me that data as to reference.
thanks
Dec 04, 2007 | Microsoft Excel for PC
Need formula to get address block into columns
If you are using MS Excel then use Text to Columns from the Data menu. Simply select the column then from the Data menu click Text to Columns & follow the simple instructions in the Dialog/Wizard.
Oct 11, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
