Question about LG WM2688H Front Load Washer
Dirt on clothes
Every once in a while we get streaks on clothes after washing. this has become a real problem. maintenance is followed in owners manual. use he detergent, drain sump, etc etc. my wife is ready to throw this out. only 2.5 yrs old. 2 people in house.please help
  • 1 more comment
  • lkathomp Jul 31, 2008
    relly disappointed in product
    they look like brown streaks that are splatttered on clothes
  • Richard Raynor May 11, 2010
    Hi, Are these brown marks or white marks like washing powder?
    Sergeant:
  • 225 Answers
Alas, that is almost certainly grease from the drum bearing escaping into the washing space through a defective seal. The seal should be replaced as soon as possible before the drum bearings fail, although that may have already started to happen.
If you cannot replace the seal and bearings yourself I would get a few quotes, but it will most likely be pretty expensive. Sorry.
Hope this guides you in the right direction. D
Posted on Jul 31, 2008
My Whirlpool super capacity 2 speed 7 cycle washing machine filter is dirty because it makes marks on clothing. Any suggestions on how to fix this please. Thanks Regards George
Hi, sometimes even after cleaning the filter dirt remains in the machine. The best thing that can help solve this problem is to buy a descaling powder for washing machine (available at supermarkets or hardware store) and follow the instructions on the box or packet, this will take awhile as you will have to stop the cycle by turning the power off when the machine is full of water (with no clothing in it) and then restart the cycle, (about 2 hours). Descaling is necessary as the soap powder attaches itself on the rear of the rotating drum and cannot be seen and some dirt(streaks) will appear on the washed clothing. Hope this helps. All the best.
Apr 28, 2015 | Whirlpool Washing Machines
White streaks left on clothes
1.Have you used too much detergent and it hasn't all rinsed out...was the machine overloaded and the rinse cycle can't penetrate the MASS of wet fabric.
2. If you are in a hard water area, could there be limescale build-up/ mineral deposits within your inlet pipes/hoses.
3. Did you use a biological powder instead of a colour or non-bio detergent and these marks are now actually 'bleached' dye lines.
Jan 27, 2012 | Electrolux EW1200i Front Load Washer /...
Sometimes the clothes come out of the washer dirtier than when I've put them in! Brown streaks that sort of come of with my finger - sort of like wet dryer lint or sludge. Rewashing takes them away,...
Your washer has too much build up of sludge from excessive use of detergent and fabric softener. You will need to purchase a package of washer machine cleaner from the local hardware store and run the washer on either "clean tub" setting or "sanitary" setting without any clothes in it. Use the cleaner at least once a week for one month and then once a month for maintenance.
Use only 2 tablespoons of detergent per wash.
Good luck
Jun 17, 2011 | LG WM2301HW Front Load Washer
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
There are streaks (lint?) left on clothes after
It is not on the machine, it is on the detergent that you are using and the amount of water for per grams of detergent, maybe you are putting to much detergent, try to lessen the detergent and more water instead.
Nov 06, 2009 | Kenmore Washing Machines
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Calypso grey/dirt streaks
THIS SERVICE POINTER APPLIES TO THE FOLLOWING BRANDS:
LAUNDRY PRODUCTS REFRIGERATION PRODUCTS KITCHEN PRODUCTS
COMMERICAL LAUNDRY
OEM BRANDS
ALL SERVICE POINTERS ONLINE: http://www.servicematters.com/tech_ref/tech_ref_main.htm, SERVICE POINTERS
COMMERCIAL LAUNDRY ONLY: www.whirlpoolcorp.com/cltpsc, TECHNICAL INFORMATION, SERVICE POINTERS
To receive pointers by email or FAX, or to edit or delete a current email or Fax from our distribution, see
http://www.whirlpoolcorp.com/cltpsc/feedback/feedbacksubscribe_all.html, or FAX changes to 269-923-5342.
CALYPSO WASHER
Model: GVW9959K
Serial Code Date: Prior to CP44
GRAY MARKS OR SMUDGES ON CLOTHING
L8178406
October 2003
Gray marks, streaks or smudges on clothing after a wash
cycle.
CONDITION:
CAUSE:
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer.
Jul 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM2688H Front Load Washer Logo
129 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
