Question about HP Color LaserJet 2600n Printer
Magenta backgrounding Hi sirs, I've had a problem with my magenta cartridge for hp color laserjet 2600n. Every time the printer prints a job there's like a magenta color backgrounding in the sheet. thank you for helping me
  • 89 Answers
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Posted on Aug 02, 2008
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
My hp colour laserjet 1200n printing red background
The magenta toner cartridge is probably defective. If you take the cartridge out and open the flap and see magenta toner all of the drum then it needs to be replaced.
Sep 04, 2010 | HP Color LaserJet 2600n Printer
Hp lazer jet 2600N won't print red color what will fix it. Has a new cartridge
You may need to replace FORMATTER BOARD & DC CONTROLER BOARD ASSY which are located behind the printer. Both BOARDs are side by side together. Just open the back cover, you will see it.
Jun 10, 2010 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n problems
changing magenta cartridge wont solve this problem.
You have to visit HP sevice.
They have to clean mirrors inside LS assy and this will fix your problem.
P.S. For more info follow this
http://www.fixya.com/support/t3117088-red_color_very_faded_best_looks
Apr 28, 2010 | HP Color LaserJet 2600n Printer
I have a HP 2600n Laserjet... When I print a sheet my red toner seems to bleed in the paper that I am printing on...
Try doing a few calibrations.If this doesnt work then change the Magenta cartridge. It sounds like the cartridge is faulty.
Jan 03, 2009 | HP Color LaserJet 2600n Printer
Hp c 1515n printer
Replace the Magenta Toner Cartridge
If you have a problem with a color replace that color toner.
Sep 22, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
First of all clean the contacts in the printer for the magenta cartridge, if there is no improvement replace the magenta cartridge, if that doesn't work come back to me
Jun 12, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
416 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
