Question about Lexmark T642 Laser Printer
SE Menu for Lexmark T640
I was hoping someone knows how to access the SE Menu on a Lexmark T640 printer. I need to reset the NVRAM.
Thank you
  • Filard Jul 31, 2008
    I actually found my own answer. You have to scroll to the TCP/IP setting, then press the left and right buttons at the same time. This will bring you to the SE menu. In there you will find the NVRAM.
    Problem Solver:
  • 5 Answers
Its a two key combo. Try the following;
Press and Right arrow and menu together and power on printer OR
Press and Right arrow and GO together and power on printer
Posted on Sep 11, 2008
Lexmark T642, I forgot my Admin password
- Select "Reinit NVRAM" Method 2 (with Config Menu): - Press c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image006.jpgwxctwy11ul1zqaaaabjru5erkjggg== and c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image004.jpg pz+7jx7h3zm6uuwsrlxaaaaaelftksuqmcc while POR - Select "Factory Default" -> - Select "Restore Network" - - Press wxctwy11ul1zqaaaabjru5erkjggg==c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image006.jpg If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
Aug 24, 2012 | Lexmark T642 Laser Printer
Forgot admin password
Hi, What you need to do is to reset the NVRAM. That will also delete your network information and passwords you set for the printer. Please see steps below: Method 1 (from Standard Menu): - Network/Ports -> press LEFT ARROW button and RIGHT ARROW button simultaneously -> Select NVRAM -> Select "Reinit NVRAM" Method 2 (with Config Menu): - Press CHECK button and RIGHT ARROW button while POR -> Select "Factory Default" -> Select "Restore Network" -> Press CHECK button If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
Lexmark t644 how reset nvram
Entering Configuration Menu
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
Then Go to Factory Defaults
This setting enables a user to restore all the printer settings to the original factory settings. Selections are Restore Base and Restore Network. Network does not appear unless you have a network printer. The following settings are not changed:
• Display language
• Settings in the NETWORK/PORTS MENU group.
This resets the non-critical areas of the user NVRAM
Jun 30, 2011 | Lexmark Office Equipment & Supplies
I HAVE GOT AN ERROR 900.00 SERVICE ON MY LEXMARK T640 PRINTER. WHAT DOES IT MEAN?
This link explains error 900 on a Lexmark printer. It includes troubleshooting steps in trying to resolve the issue.
http://www.marketpoint.com/article.cfm?id=100
If problem persists, contact the manufacturer.
I hope this works for you!
Thanks.
Monkey
"Understanding explains better..."
Jan 21, 2011 | Lexmark T640, T642, T644 250-Sheet Duplex...
How to replace the power supply unit on the Lexmark T640
hi. I wold like to know the output voltage from the several pins in the low voltage area (the blue wires connection) in the power supplier of a Lexmark T640.
Sep 20, 2010 | Lexmark T640 Laser Printer
I need a manual for lexmark lase printer t640 or
You can download the complete user manual from the manufacturer's website by clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Feb 22, 2010 | Lexmark T 640 - printer - B/W - laser
Error 950.10 NVRAM Mismatch. Replaced the LCD
If the lcd that you put in came from another printer instead of Lexmark, it will say that because the lcd, riser card on rip board and rip board all contain nvram that has to be matched. an lcd from Lexmark will no have any nvram data and the nvram will be copied from the other two sources upon install. The only way to get the lcd out of another machine is to get all of the above parts from the same printer at the same time.
Jan 27, 2010 | Lexmark T640 Laser Printer
How do you reset the mainentance count on Lexmark t640 printer.
Enter the Configuration Menu:
2. Press and hold (check) and (right arrow).
4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel shortly.
5. Scroll to Reset Maintenance Count from the Configuration menu and select.
6. Press (check) to reset count.
Oct 08, 2009 | Lexmark ImageQuick SIMM (15W0000) for PC,...
Nvram mismatch error after replacing the dislay panel on lexmark t644
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Mar 30, 2009 | Lexmark T640 Laser Printer
Looking for a Lexmark Optra T640 Service manual ??
Those links do not work. Stop trying to make money off of material that doesn't belong to you.
Please someone post a link to a FREE download.
Jan 28, 2008 | Office Equipment & Supplies
Lexmark T642 Laser Printer Logo
2,734 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
