Sounds like you have a thermostat problem. If your thermostat is not triggering the furnace to ON/HEAT you will not the heat you desire. IF you know how to trigger the furnace you could jump your furnace controller wires BUT DON'T do this. Instead, get another thermostat and try it. But be sure to get the same rated thermostat... take it with you when looking for a replacement.
Not sure about everything going on with your unit based upon what you provided but your thermostat should show the current temp and the temp you set. It also show the mode that the thermostat is in (HEAT / COOL / AUTO) Manually select heat, then increase temp above the current temp setting. listen for furnace to activate or wait a few minutes for warm air output. If not, you'll have to see assistance trom a local heating and cooling company.
