Question about DeLonghi Heating & Cooling
Delonghi ct300 air conditioner is blowing warm air not cold
  • 9 Answers
SOURCE: Delonghi Pinguin Air Conditioner
I sat on hold with Delonghi for about 25 minutes before I talked to someone this morning.  Expect a long wait before you get helped.
For this specific problem (unit works, just doesn't blow cold air), the unit MUST be sent to an authorized repair facility.  No repair facilities in Texas.  The closest one to Texas is:
All-Brands Appliance 5008 W. Linebaugh Ave. Suite #8 Tampa, Florida 33624 813-908-2002
Delonghi said they will cover mine under full warranty up to 13-months.  No RMA needed, just a photo copy of the purchase receipt for the unit. Outbound shipping is something not covered by Delonghi, but they will pay for parts, labor, and return shipping.
All-Brands said they don't have any specific requirements for packing, other than making sure the casters on the bottom of the unit are well-protected.  It is common for them to break during shipping.  They recommended, though, that if you have someplace nearby that does professional packing, like a UPS Store, to take it there.  It's not a requirement, just a recommendation.
Along with the unit send a copy (not the original) of your purchase receipt, your name and telephone number, and the address to where the unit will be returned.  Also, include a detailed description of the problem with your unit.
I REALLY hope this information helps someone!
Posted on Jun 09, 2008
  • 54 Answers
SOURCE: my cooper line outside on
The evaporator coil that is low pressure and low temperature needs an adequate supply of heat to absorb from air passing over the fins or a thin dusting of frost will begin to form further insulating the coil from the passing air and causing more ice to form. First you have to get rid of all the ice by allowing the coil to thaw you can use a heat gun or hairdryer or lamp to speed the thawing but the fins and copper tubing are thin and easily damaged so don't use tools on the coil to remove ice. After thawed the coil needs to be cleaned with an indoor evaporator cleaner ( I also use a small shopvac and nylon brush) Then be sure that the filter is clean and the blower is functioning properly then if the suction line is still frosting you will have to verify that the size of the outdoor section is not over sized in relation to the evaporator coil and that the system is charged to meet the compressors manufactures specifications.
Posted on Jul 21, 2008
  • 14 Answers
SOURCE: coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
  • 534 Answers
SOURCE: Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Posted on Oct 17, 2009
demonicsaint
  • 160 Answers
SOURCE: air conditioner only cools sometimes
Your convergence is off. See the owners manual or call tech support to walk you through a convergence.
Posted on May 06, 2010
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Not Cold Does not cool warm air comes out of it
The compressor is locked up and making heat..
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Blows Warm Air
My RV Air Conditioner only blows hot air (and NO, its NOT a heat pump) Anybody got any ideas???
Apr 05, 2010 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Not blowing cold air
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Extendable hose in water tank
I went online and did some research. I couldn't find your model number but I looked at some others because they are all pretty much the same. I couldn't even find a replacement part for it. But I think it could be something that catches so the hose can not be pulled out of the tank. You can contact DeLonghi by email if you go to their website. www.delonghi.co.uk You may get more information from them plus they will be able to get you a manual for it as well. Good luck to you!
Apr 01, 2009 | DeLonghi Heating & Cooling
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
May 19, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
43 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
