RD-XS24SB HD/DVD player / Recorder Has died. Looks like power supply failure. Where can i get:- 1. A replacement power supply board 2. A circuit diagram of the power supply to allow me to fault find. 3. Is this a known problem with the power supply whats the fix
  • 2 more comments
  • Barney147 Jul 31, 2008
    How much is the manual?
    I have looked on this web site and cannot find any ref to this model RD-XS24SB
    The model RD-XS24SB is not on this website. Am i missing something because i cant see it?
  • Anonymous Mar 20, 2014
    Dr-1
    Genius:
  • 2,035 Answers
Please check if the fuse is blown out in the player and like to perform DIY on the DVD you will need a service manual to guide :
Please use this link to get one :
http://www.user-manuals.com/advanced_search_result.php?keywords=Toshiba+RD-XS24SB+service+manual&forward=plist
Good luck..
Posted on Jul 31, 2008
  • 10,594 Answers
Service Manual will tell you, how to fix power supply of this DVD Player or need to replace completely.
Following weblink has info for service manaul. This might help you.
http://www.eserviceinfo.com/index.php?what=search2
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    Please write Model Number is Search Box and get result for Service manaul. Picture is attached for reference.
    Guru:
  • 1,894 Answers
The circuit diagram can be found in a service manual only. and service manual is not available free.
are you willing to pay for the manual?
  • 1 more comment
  • dewan nafees ahmed Jul 31, 2008
    its 15$ this will give you detailed info about the component needs to be replaced and all other instructions as how to do the repair.
    click here to see the service manual page.
    also the problem you are facing is due to a burnt capacitor or a heat dissipater in the power board.
    you can even see the component damaged by just opening the player and by having a manual check.
    power board problem comes due to a bad power supply where the components get damaged due to a surge or any return current.
    and hence it is safe to use a surge protector to save you player from damage in future..
    hope this will help you
    thank you
    have a great day
    as soon as you click the link you can see a page open with two manuals showing in the list.
    first one is owners manual costing 9.99$
    second is service manual costing 14.99$
    click here for the link
    the original link is this
    thank you sir.
    everyone here is able to see it sir.
    am not sure what is preventing you from seeing that.
Panasonic dmr-es30v will not turn on
The circuit board may look good, but a power surge can damage the tiny resistors, diodes, and transistors. Any one of those mention can render the unit inoperable.
Feb 27, 2014 | Panasonic DMRES30V DVD Recorder/VCR Combo
Toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
Jun 05, 2012 | Toshiba Televison & Video
Its a Toshiba RD-XV49DT DVD/DivX/VHS Player/Recorder Combo, replaced power supply board as was blowing fuses found components have shorten out and now after replaced board, video works and i think hard...
The controller circuit (usually a small board connected directly to DVD drive - it is either part of the drive or a sub-assembly which is attached - and contains several ICs and small capacitors and a lot of surface-mounted components on its copper side) is probably faulty, possibly due to the original bad PSU (which you have since replaced), chances are the original faulty PSU has damaged this circuit - usually DVD drives operate around 12V DC or so. The digital controller circuit/board not only has the EEPROM/CPU etc. on it, but also has a servo supply - for the DVD (the VCR servo supply is on the motherboard). This powers the disc tray and traverse unit. The controller is not serviceable at component level; it must be replaced and in some cases, the DVD drive must also be replaced where the board is not separate to the drive. This may not be economical.
It may just be a simple case of a blown digital controller circuit - but be warned, this board is not cheap - it is part of a 'module' (the disc drive and controller together = DVD module), and you may not be able to obtain the board without a new DVD drive. Up to you what you do from here, and you might be lucky in terms of the motherboard and HDD - no damage there.
Apr 11, 2011 | Toshiba Televison & Video
I have a Toshiba RD-XS27KE DVD/VR. It does not perform any recording on the HDD - error code E49. I have deleted titles and it still does not record. What can I do ?
I fixed it by 1. delete all on HD drive (a function described at the end of your manual) 2. turn off your recorder 3. turn on your recorder 4. now should E49 not be vivible and recording function again
Jan 31, 2011 | Toshiba RD-XS32 DVD Recorder
DEAD, NO TURN ON, CHECKED INTERNAL FUSE OK
If the internal fuse is okay, then what you got here is a bad power supply. Many power supply's do die with the internal fuse intact what happends is the High voltage tranformer or relay goes out on you causing this to happed, Best thing to do is replace the unit becuase a new power supply would cost you more then the unit new. Let me know if you have any question.
please do not forget to rate.
Aug 10, 2010 | Toshiba RD-XS32 DVD Recorder
I have a Sansui DVR5013H DVD recorder. It stopped working a few weeks ago. There is a light on it that is normally blue and it goes red if it is recording. That now lights up purple. I took the lid off and...
My DVR5013 has a faulty power supply as well, I replaced 1 cap and it was working ok for a while but now it looks like the FET has died, another on order..
Has anyone got a circuit for this beasty?
Seems that the major problem with these units is always the Power supply, low quality, cheap and nasty.
Nov 24, 2008 | Televison & Video
Toshiba rd-xs32
i've attached the hd to my pc but when i put it back again on my dvd toshiba i got 7034 error and it stop i cannot access no more in my dvd recorder and i didnt see my recording movies on my pc too.please help me very urgent thnx.
Oct 19, 2008 | Toshiba RD-XS32 DVD Recorder
Power Supply Toshiba RD-XS24SB DVD Recorder
I have sent you correct page link, though manaul is availabale on charge basis $25.00 Give a close look at tha link ;)
Jul 31, 2008 | Televison & Video
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS35 DVD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
