Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
Cassette player in car
My cassette player says there is a tape in the player when there isn't one. When I try to put one in it makes some clicks and spits it out again. We were using it with a mp3 cassette adapter. I have tried putting a regular cassette in and it does the same thing. Thank for and help!
    Sergeant:
    Champion:
  • 319 Answers
Unit has a problem with loader mechanism, have serviced
Posted on Aug 03, 2008
How do I take apart the body to get to the drive of the tape cassette...??
There are thousands of happily outdated cassette players and actually you don't even specify make and model of yours so all I can provide you are these links:
How to fix cassette tape
Old cassette tape player taken apart
Disassemble the Cassette Player
Take apart tape player
Jul 03, 2015 | Audio Players & Recorders
Cassette player wont play
hi ya
this is quite a common issue with tape head cleaners, try loosening the tape a little, and see if this helps,
Jan 14, 2014 | Jwin JC-13 Wet/Dry Cassette Player Head
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
Jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Apr 28, 2009 | Car Audio & Video
Car cassette player
sometimes to play a cassette, you got to put it in the oposite way to the tape run, depending which way your player is set inside. Try this. If it fails the load spring may be bust, new one can be got at a motor factors.
Sep 26, 2008 | 1994 Jeep Grand Cherokee
Cassette player connection
hi there, you just have to make sure that you're cassette deck is clean..then try it...if it won't work, you have to buy a new cassette adapter..i can assure u it'll definitely work..
Dec 03, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Tape witll not play
your tape player may be jammed up and not playing your cass.
Jul 04, 2007 | Sony Walkman WM-FS593 Personal Cassette...
Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
206 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
