Keyboard & mouse
While working on a desktop computer keyboard & mouse quit responding. Both plug into ports on backside of computer.
Rebooted XP Windows still same problem. Installed a USB mouse it works.
Num Lock will not light on keyboard.
Took old keyboard to work and used it there no problem works fine.
I feel at this time the problem is in the motherboard. Any other ideas?
  • 8,637 Answers
Make sure batteries are good in both the Keyboard and Mouse. Then press the button on the Receiver.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
I have a HP Pavilion s1600n with Windows XP Media Edition. The keyboard and mouse have stopped responding. Both are properly plugged in
if you are sure that your mouse and keboard are in good condittion and it is all ps2 port type the problem maybe the system driver for keyboard and mouse of your operating system, please get an extra usb port type keyboard and mouse and plugged it in to your pc and power it on the usb type keyboard and mouse may refresh the system driver and may read again your ps2 type keyboard and mouse.
Sep 04, 2011 | HP Pavilion a1600n (882780776265) PC...
Can I use a mouse and keyboard with a USB port?
Yes, you can use a USB mouse and keyboard. Just plug those devices at the back of your computer. Restart the computer if the devices do not respond.
Thank you for choosing FixYa!
Apr 23, 2011 | E-Machines eMachines T3830 PC Desktop
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Computer will not respond to any commands
Make sure that the keyboard and mouse wires are plugged in the appropriate ports, if it still won't work, try switching keyboard and mouse. If it still will not work I would call the factory and try to have it shipped back because it could be blown ports.
I hope this helps some.
Apr 02, 2008 | Compaq Presario 5000 PC Desktop
Keyboard/mouse not working
You need to restore to a previous date before you installed the wireless mouse / keyboard.
If that dont work then your only solution is to format and reinstall since it might be you could have damaged a few vxd files window's needs to use those devices
if that wasnt done
shut down compuer
2.) plug mouse into green ps2 port and keyboard into the blue one
3.) turn on computer
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
