RADEL CR 208 temp not staying at low setting
When I put the setting to 17 to doesn't stay and goes back to the highest setting. Is there a Manual in PDF format somewhere?
3 Suggested Answers
SOURCE: RADEL CR 208 PORTABLE AIR CON UNIT
DOES ANYONE ACTUALLY ANSWER ANY PROBLEMS ON THIS FORUM?????????????????
Posted on Sep 21, 2008
ZJLimited
  • 17970 Answers
SOURCE: There is a red lamp
Tank full: When the air conditioning unit is operating in air conditioning or dehumidifying mode, the condensation is collected in a special tank.
When the tank is full, the "tank full" indicator light on the control panel flashes.
Remove the condensation tank, empty and replace on the unit as shown in the following figures.
NOTE:
1. While the air conditioning unit is operating in air conditioning or dehumidifying mode, do not extract the condensation tank before it is full, otherwise a buzzer will sound indicating that the compressor has stopped. The unit will switch to FAN mode.
2. To remove the tank before it is completely full, the unit must be stopped by turning it off or operating it in FAN mode only, waiting about three minutes to avoid the condensation dripping outside the tank, then removing the tank.
3. Do not remove the cap of the tube in the water tank compartment (present in certain models only) while the unit is operating with condensation collecting in the tank as this could lead to leaks of water.
Hope this helps.
Posted on Sep 23, 2010
Ge profile refrig temp will not stay set
When you set it it goes back to actual temp inside the box. Works its way down to your setting. Service manual and more HERE
Dec 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My iron temp cuts off and only stays at a low temp even thou it is at it highest settings regards Mike
It is possible that the BIMETTALIC cut off is OFF set and so the cut off happens vry early .
You might need to remove the unit and get access to see if this can be set to higher level- tighter- so that the bimetal takes more heat to cut off. This will provide you a higher heat.
You can calibrate using the highest/lowest settings.
Aug 08, 2011 | Philips GC 148 Iron
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
I have an airconditioning machine RADEL CR-208. There is a lamp flashing saying that something is full. I got an answer from you that the condensation tank is full. I followed your instructions and noticed...
i just had same problem i old used aircondition i didnt know about litle plastik top of the tank. i put it on and red lamp shuted down and aircondition is cooling . wohooo.
Sep 25, 2010 | Heating & Cooling
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Coolant temp stays low
I believe when they replaced head gasket they installed too cool of a thermostat in it. need to replace thermostat with proper one should probably have a 195 degree one in it
Nov 06, 2008 | 1998 Dodge Stratus
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Jun 24, 2008 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
