Question about Dell Dimension 2400 PC Desktop
Blinking power light on desk top monitor
The power indicator light on the monitor is blinking versus a constant light. The screen is blank. How do I get a steady light?
  • 37 Answers
-Check to see if your VGA cable(the cable from your monitor to your PC) is properly connected.
if not
-unplug your PC
-remove all devices connect to it(make you remember where each component id connected)
-remove the cover
-unscrew the Graphic Card
-clean the contacts with pencil eraser
-reseat the Graphic card(make sure its is properly seated
-screw it in place
-put the cover back
-plug your pc
if this also fails
-you might have a defective graphic card
^_^
Posted on Jul 31, 2008
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
At the desk top, I moved the mouse to begin and the screen went black. All it gives is a blinking orange light. Pressing the switch doesn't matter. Upon rebooting , blinking light persists while you can...
Sounds as though you have a backlight issue. How old is the monitor?
The keyhole with the lock sign is for a security lock to lock the monitor to a desk so it cannot be stolen.
Mar 08, 2011 | Acer AL1916W 19" LCD Monitor
My monitor is blank. The power light is blinking ...
Throw it Away and buy a new one (its cheaper)....
May 14, 2010 | Computers & Internet
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
Feb 22, 2010 | Samsung 906BW LCD Monitor
My hppavilion f1503 flat panel lcd monitor screen stay blank
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 04, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
LG L194WT Monitor suddenly stop working
it is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the culprit...you need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
qube
Jun 06, 2008 | LG Flatron 563LE 15.1" LCD Monitor
"BLANK SCREEN, CLICKING SOUND, & NO LED INDICATED".
some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Dec 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
Dell Dimension 2400 PC Desktop Logo
108 people viewed this question
Alun Cox
