Boiler comes on fan runs but no ignition. - Heating & Cooling
  • 1,420 Answers
Bad igniter or bad gas valve. Try replacing the igniter 1st.
Posted on Aug 01, 2008
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
Exhaust and fan motor run, but why won't furnace ignite?
Are you referring to the combustion blower on your furnace? Cause if you are then maybe this answer will help. The hose coming from the inducer blower may have holes, and or the safety pressure switch is not working.
Nov 17, 2015 | Heating & Cooling
I have a baxi combi boiler which wont start and trips the electric..plumber has changed fan,ignition and now pcb to no effect...help!
Start by diconnecting main supply to Boiler (at the boiler input) and see if it trips the electric. This would point to fault in wiring from board to boiler.
Then check several points with meter to find short-circuit.
If not, then you have to TURN OFF THE GAS SUPPLY and connect and disconnect items such as solenoids, switches, board etc; until you find what causes it to trip.
Nov 18, 2014 | Heating & Cooling
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
Fan runs continuously
the air pressure which does not controll the fan it is a safe guard for the gas/oil burner to ignite nowing that the fan is running ( air switch normaly negative /positive prssure n/o,n/c circuits. it could be that your boiler is designed for a cant think of techinacal name but when in centre of house/factory and has 1 or more boilers connected to flue etc the fans run when only power to boiler is on , non vented system ? it could be a simple link to remove in controll panel i would phone technical help for manufacture ?
Jan 31, 2009 | Water Heaters
Boiler Problem
what do you mean "moved the position" of the boiler?
May 25, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
