Question about GPS
My garmin nuvi is "stuck" in its location and I can not get it to the current location. I have turned it off and on serval times and tried to go back to default as a means of getting it unstuck, but it did not work.
  • fontanasteve Apr 19, 2009
    My father-in-law's Nuvi 200w is also stuck at a location that he was at earlier today. He's reset it but it still won't show his current location. I haven't a clue how to help him.
    New Friend:
I have furuno gp-30 its display is not working due to may be it is happend by its lcd belt but i want accurate answer....! thats the reason that i am asking you. and please tell me if its display{LCD} problem, THAN FROM WHERE I CAN BUY THAT LCD AND ITS COST?????? {IN INDIA}
KINDLY REQUEST YOU TO GIVE ME ANSWER. PLEASE...!
Posted on Jul 27, 2013
5 Suggested Answers
  • 174 Answers
SOURCE: Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Posted on Jan 28, 2008
Maanita
  • 1142 Answers
SOURCE: garmin 760 is stuck on enabling bluetooth
refer to this link
http://www.garmin.com/garmin/cms/site/us/lang/en/searchsupport
Posted on Aug 17, 2008
SOURCE: Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Posted on Dec 07, 2008
rogrrabbit
  • 986 Answers
SOURCE: my garmin nuvi 360 shows my current location wrong
go and reset the home address under my locations ( the heart) under set home
Posted on Sep 23, 2009
Garmin Nuvi 755t Stuck in power up cycle
You can do two things.
First, plug the GPS in overnight in a regular USB charger. If the battery charges up, then the problem is with your Garmin vehicle cable.
If it does not charge up, you can buy a battery replacement kit for it: https://www.amazon.com/Garmin-Nuvi-755-Replacement-Installation/dp/B003VFSR4M
Mar 05, 2017 | Garmin nuvi 755T Car GPS Receiver
Tip
Garmin Nuvi 1250 Favorites Backup_2
Garmin Nuvi 1250 Favorites Backup and Restoration Procedure
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1250 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1250 Manual Download
Garmin Nuvi 1250 QuickStart Download
Garmin Nuvi 1250 Webupdate
Garmin Nuvi 1250 Hard Reset
on Jun 18, 2010 | GPS
Tip
Garmin Nuvi 1490 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1490 Favorites and Waypoints?
I hope that helps.
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Webupdate
Garmin Nuvi 1490 Hard Reset
on May 27, 2010 | Garmin nuvi 1490T GPS Receiver
I have Garmin Nuvi 265W. When I plug my car charge to charge up the battery and use the Navi at the same time, I only get the "GARMIN" screen connected the computer but can't use Navi function...
Try a hard reset,the Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  4. Press "yes" and the unit will reboot. This resets all your location settings and user preferences
Then make sure the unit is fully charged,then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 01, 2011 | Garmin Nuvi 265W GPS Receiver
My Garmin is stuck in simulation mode at one of my last locations
all garmin nuvi users reset device small button on bottom then plug into computer using usb cable back up the nuvi folder in my computer,just in case, then run virus check on device`s nuvi folder when finished unplug safely , hopefully should be back to normal i have down this with 2 nuvi`s with keyboard problems and it has worked both times hope works for you regards brettjohns1350@bigpond.com
Jun 15, 2009 | Garmin Nuvi 660 GPS Receiver
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
I hope that helps.
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Pin code for garmin nuvi 260
Find out where your "friend" did the code. If you don't know what it is, then you have to go back to that exact location where they did it and it will automatically unlock it for you. Then you can follow the instructions below:
Answer: If you can remember the PIN Code previously set on your device you will be able to change the Pin on your device easily. You can change the PIN on the unit by doing the following:
Zumo's, Street Pilot Cxx, Nuvi 3xx, 6xx
  1. Turn your device on
  2. Touch the Spanner symbol
  3. Touch System
  4. Touch On/Off next to Garmin Lock
Within this section you can add or change a PIN.
All Nuvi's excluding 3xx and 6xx
  2. Touch Tools
  3. Touch Settings
  4. Touch Security
  5. Touch On/Off under Garmin Lock
When the Garmin security lock is set it locates the units current GPS location.
If you are trying to change the Garmin Lock and are not within the same location to where the Garmin Lock was set you will need to revert back to this GPS position.
Once at this position you will not be prompted to enter the PIN Code when starting the device up and can change the code as you please.
Mar 31, 2009 | Garmin nuvi 260W GPS Receiver
Tip
Garmin Nuvi 1370 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1370 Favorites and Waypoints?
I hope that helps.
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Hard Reset
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1200 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1200 Favorites and Waypoints?
I hope that helps.
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Webupdate
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | Garmin nuvi 1200 Car GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
