Question about Frigidaire Refrigerators
I have a frigidaire refrig side by side, the ice maker just started getting stuck maybe too much water,now its just frozen solid at will not push ice out
NECESITO TELEFONO SE SERVICIO TECNICO EN LIMA PERU PARA REFRIGERADOS ELGIN.
arlitamorales198@yahoo.com
Posted on Jul 31, 2008
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker is not working
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not producing ice,already check the basic problems,
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice makere is not making ice
Several Solutions.
Icemaker filler tube inside the refrigerator frozen. Thaw out with hair dryer. Shut off water, disconnect water inlet line to the ice maker. Insert a flexable item - I used a zip tie through the inlet linlet fitting to make sure the tube was clear. Re-connect the line and you should have ice soon.
2nd Solution, replace the water inlet valve to the refrig. at bottom back right of refrigerator. Easy To Do.
May 30, 2010 | Frigidaire FRS26H5AS Side by Side...
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Inconsistent ice maker
If you hit the ice maker or do you hit the water filter? if you hit the ice maker then I would say you need a new ice maker if you are hitting the water filter then you may have a frozen water line.
Aug 09, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
May 10, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
85 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
