Question about Kenmore 43142 Front Load Washer
Not filling with water
Kenmore front load washer not filling with water. Magnet fell out of det dispenser area. Cannot find where it is suppose to be located.
  • hiteam Aug 04, 2008
    My detergent dispencer fell off today, the face was broken off for over a year and I just slip it into place and it works. This time the water refused to fill and a code ddo came up on the the min. left display. I did notice a magnet on the bottom of my washer. I thought it was one on my childrens. It is rectangular approx 1"x1/4",x1/4". I never thought that it had anything to do with the problem of the water not filling up now I am not so sure
    New Friend:
Answer: The magnet goes on the back of the dispenser door. Pull entire dispenser out per instructions elsewhere in manual as if you were going to clean it. Turn it around so that you are looking at it from the back end. The magnet goes vertically on the very left edge (as you're looking at it, right edge when dispenser is in machine) of the back of the white outer cover of the dispenser about halfway down. If you run your finger along the left edge (the edge of the back of the dispenser) you will find a "cut out" area. The magnet goes immediately to the right of it between the edge and the portion of the dispenser that sticks further out toward you. There is a small clip to hold it in place.
I found instructions somewhere on the web similar to these that helped me locate it , but can't find it now to link or give credit. I have added some photos I took to help schematically challenged folks like myself.
PS If you need bifocals remove the front cover from the dispenser, take your glasses off and look at the far middle left of the back of the dispenser cover. It's really hard to see.
Posted on Apr 16, 2014
Hi mine did the same thing. Remove the Dispenser door. If you take the magnet you will notice that on the right side, inside of the dispenser, is magnetic as well . If you than place the magnet the bottom of the faceplate on the same side (there is a groove). The Magnet is sort of on an angle. Hopefully this helps.
Posted on Aug 08, 2008
My Kenmore front load He2 fills with water in the dispenser cup then spills out from the dispenser cup onto the floor. Can anyone help?
SOLUTION...DON'T BUY THIS PRODUCT. THEY ARE LEMONS.
Kenmore you failed. Claudia Bennett, Boston
claudiabennett80@aol.com
I should have kept the older unsophisticated model ...my basement smells...I did not know I am supposed to be a technician to wash my clothes!!!!!!!!!!!!
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Magnet fell out of the soap dispenser and now the washer will not fill with water
The magnet needs to be located on the right side of the dispenser housing it is there so the machine knows the drawer is closed. The link below will show the location of the magnet which is part number 51 near the bottom of the page.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0503093-00001.png
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Magnet fell out of dispensing drawer and I don't seem to be able to find where to replace it. Washer will not start without it. Kenmore model 417 44152400
I dont see why there would be a magnet in the dispenser draw in the first place,,,, is it possible it somehow got in there by accident and when it fell out you thought it belonged in there ?
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Magnet came out and now washer won't run
on the under side of the dispencer, remove it, flip it over, fit it in with some glue, as far toward the inner part as possible, put it back, try the washer, if it still doesnt fill, try pulling it out a little and see if that works, if it does this is the amount you need to move the magnet back.
Feb 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore washer
pull drawer out on right side just behind outer cover there should be a area where magnet fits if can't find exact spot hold magnet along right edge of opening and turn washer own if nothing happens move magnet along right edge till it comes on glue mahnet to dispenser drawer in corresponding area
Aug 15, 2008 | Washing Machines
Kenmore 43142 Front Load Washer Logo
179 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
