Question about Vulcan EF3 Deep Fryer
Control valve leaking (Vulcan LG300 Propane fryer)
Gas control valve will not turn. gas is leaking from small plug to the right of the control valve.
  • 21 Answers
Must change gas control valve which will repair leak also
Posted on Nov 19, 2008
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
May 23, 2014 | Vulcan Kitchen Appliances - Others
Commercial propane fryer wont light
If the pilot won't light, the first thing to try is to replace the thermopile, assuming you have a good flame on the top portion of the thermopile in the first place when you hold the gas valve in when in the pilot position. If this does not solve the problem, which in 90% of the cases it will, the gas valve is defective. I usually replace the thermopile when replacing the gas valve and save the old one for a backup.
Feb 06, 2014 | Vulcan GR45 Deep Fryer
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
How do i calibrate a lg300 gas fryer
I don't know that you can calibrate a thermostat on a deep fryer...Is your thermostat bad? Is the temperature setting off? Is it working at all? You could call Vulcan directly and ask for the parts/warranty dept and they could tell for sure if calibrating is possible or not... If not, and you need a new thermostat, then they can point you in the right direction for a dealer that sells their parts...
If I can help in any other way, call us at 888-542-5959. Thanks, Susan @ Restaurant Equipment Outlet, Cincinnati, OH.... www.restaurantequipmentinc.com
Aug 27, 2011 | Vulcan LG300 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Vulcan 2grc45 fryer can it be converted to propane
All gas operated Fryers can be converted either from propane to natural gas use or from natural gas to propane use. Contact your local supplier on your country and and ask for the conversion kit.
Apr 01, 2011 | Vulcan Kitchen Appliances - Others
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Label says propane, needs to run on natural gas.
You need to change the gas valve,burner orfices,pilot and maybe a gas regulator.I service these fryers often as im a hobart tech.Goto hobartcorp.com,type in your model and the parts list.Any ? let me know.
May 06, 2009 | Vulcan EF3 Deep Fryer
Vulcan Deep Fryer, burners shut off, remains off!
sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Dec 07, 2008 | Vulcan EF3 Deep Fryer
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
Vulcan EF3 Deep Fryer Logo
283 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
