Question about Ricoh Caplio R30 Digital Camera
LCD screen black, no viewed image displayed.
Hi, hope you can help. Camera switches on ok. Message appears 'in synchronized monitor mode' then LCD screen black, but icons appear ok. Have tried restoring factory settings but this does not solve it. Because of the way I was holding the camera, the flash reflected making the photo's red. Camera ran very slow to read pictures, then when I went back to take a picture it says "in synchronized monitor mode.." and turns black. Can't fix this. Please help.
  • Anonymous Dec 28, 2008
    my r7 is doing the same thing
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Posted on Dec 28, 2008
Powershot SD1000 Cannot get an image on the LCD Monitor while in camera mode but previous pictures can be viewed normally. Other functions of the camera appear to work properly. I replaced battery--no...
HI there when you go for click the image that time on your LCD screen. Right now its off and its in viewfinder mode. So press the switch for LCD on so , you can see the image in LCD in camera mode. Thanks.
Mar 26, 2010 | Canon PowerShot SD1000 Digital Camera
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Powershot A610 monitor doesn't show image view in camera mode
Hi there. I can help you with that. First, make sure your in shooting mode. Then press the Display button. There are 3 modes: Standard, Detailed and Off. Each press of the Display button scrolls you through each of the modes. Try that, and it should fix you. Let me know if you have any problems or if I can help you any further. Please feel free to rate my answer appropriately if you find it satisfactory, and thanks for coming to FixYa.
Rob
Feb 21, 2009 | Canon Cameras
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Problem with lcd monitor
in the rear side display mode switch is there. you just press the switch once or twice.you can able to see live images
Apr 28, 2008 | Canon PowerShot A460 Digital Camera
Internal video out connection may be bad, try using the provided cable to connect to TV and disconnecting to see if it returns to normal.
Apr 30, 2007 | Ricoh Caplio GX Digital Camera
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Ricoh Caplio R30 Digital Camera Logo
343 people viewed this question
Top Ricoh Cameras Experts
Cleverer2
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
