Question about Vacuums
  • 3 Answers
12  HP
Posted on Aug 13, 2008
Need complete detailed vacuum diagram for 1995 460 Ford fuel injected
1993 460 vacuum diagram - Ford Truck Enthusiasts Forums
May 4, 2012 - 1993 460 vacuum diagram Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) ... The vacuum diagrams for most of the EFI engines are pretty simple since... 1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver) ... All the Forddiagrams I have seen have the CCD in 1994 including mine (no ... De-smoging EFI 460
Apr 24, 2012
5.0 EFI Fuel Injection issues
Feb 8, 2012
More results from
Vacuum Diagrams - AutoZone
AutoZoneFord Pick-ups and Broncos 1987-1996 Repair Guide ... 14: Vacuum diagram-19955.0L engine, Bronco models ... 15: Vacuum diagram-1995 diesel engine.Missing: injected
Jan 20, 2016 | Vacuums
Rainbow vacuum cleaner won't turn on.
The 4 main problems we see is #1 The Plug needs replaced due to lack of continuity and #2, the 2 pole 2 throw on off switch has failed on the 120 V motor side of the switch.
One side of the switch is for the main motor and the other is for the power to the power head socket on the vacuum it self.
The 3rd is the motor brushes are seized due to a dirty motor or 4, the motor's armature is blown
Check the continuity of the 120 V cord first, then proceed onward.
I hope this helped!
William R
Feb 01, 2015 | Rainbow Vacuums
My acuru tl still moves when put in park and grinding noise when you put it in park
You need to have your auto box serviced,they give you new fluid filters and re set the box to the engine. Cost is aprox £120.
Jan 02, 2015 | Weapon-R Acura TL 3.2L 1996-1998 Secret...
2005 chevy cobalt electric power steering issues. "power steering" lights up on the dash, and the transmission shifts hard, engine lacks power.
Sounds like either the TCM (Trans control module) OR the plug from the TCM going into the CAN Bus. Check out the Youtube video for checking the CAN resistance... might save you big bucks!
Sep 16, 2013 | Vacuums
I have a vintage GE coffee perculator made in the 1930's and 1940's Cat No. 119P102 which I bought from an antinque store in Chicago 2 months ago. It has worked beautifully until yesterday morning...
The first problem is the time you will use a product of the very old time , and ask you not wonder what it mains happened in the interval between 1930 and 2016 maybe its not only the changeof 110V to 120 volts it is not much difference but far enough to worry and what the effect is on the heat dissipation of the heating element inside (the coffee must be too hot 90 and 95 degrees are normal all the cables and more parts of Should Be Replaced if it was not modifiedin all Those years, it Should Be modified, and it was modified there must be for shure a big wire resistor be Placed in serial to release to the high aC power on the heating element. and maybe many more parts. gaskets cables and more must Be Replaced iif not safety for all. preventinfo and usefull to a hot Become bitter tasting coffee temperature.
Sep 25, 2011 | GE Vacuums
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have the same problem with intermitant power, however, it does not make sense that the problem is in the upper powerhead (which is what a repair guy told me) because-- when I use the other attachements...
You can test the auxiliary plug to the roller/beater attachment with a volt meter if you know how and take precautions. Check for 115-120 volts at the beater/roller attachment plug. If voltage is there and the beater/roller doesn't run, the problem is with the attachment. If not, then the problem is in the power switch or somewhere else that feeds power to the lower attachment.
Feb 23, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Won't start
take an AC VOLT Meter and place the leads of the meter where the power cord terminates,one on the white lead and one on the black. There should be 110-120 volts AC. If that is good then move one of your meter leads to the other side of the on switch. With the on switch ON there should be 110-120 volts AC.If that is good, you may want to connect the motor directly to wall current to ensure that it is good. BE VERY CAREFULL IF YOU DO THIS!!!!!!!!!!!!!!!!!!! Before you do anything be sure to make sure that there is not a breaker or reset button somewhere on the machine that has been overlooked.
Oct 21, 2007 | Electrolux Epic 6500 Vacuum
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
168 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
