Question about Garmin GPS
Unit has been charging for two days - Garmin GPS
Removed power, pressed reset, then restored power.
Posted on Aug 05, 2008
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
I have a 500 amp battery jump-starter # j5c09ca i know i have to charge it for 40 hrs before first use. after that do i have to charge it for 40 hrs.each time
No you do not. You are supposed to charge it for 24 hours before the first initial use. After that you are supposed to charge after it using it to jump start a vehicle or every 30 days if not used at all.
You are supposed to charge until the two red and one green LED lamps are lit SOLID. The unit should be fully charged once the LEDs are lit solid. Unplug the unit and put back into storage until needed. Again if not used for extended periods of time the unit should be charged ever 30 days.
Mar 05, 2011 | Stanley Garden
How long does it take to recharge my oral b toothbrush and should it work when put on charger sraight away
The first time you use the unit, it should be charged for 24 hours or more.
When it needs charging, my unit takes over 24 hours to fully charge and then lasts around 14 days until it needs another charge.
Is this helpful?
Gary
Feb 28, 2011 | Vacuums
My e reader prs 600 isn't holding a charge for more than 2 days
Without knowing the background of your experience with the unit, it is a bit hard to determine if it is a hardware / software problem. I suppose the first thing is to decide is, are there any habits that you have developed when using the unit that may contribute to the problem of rapid battery deterioration.
When you are using the unit, do you leave turned on for long periods in between reading sessions?
When you finish using the unit, do you switch off by gently sliding the off switch or do you completely turn it off by sliding the switch to the right and holding it for 2-3 seconds?
When you charge the battery, are you confident that the battery is fully charged before disconnecting? (The handbook will help to describe when this state is achieved.)
I guess you are using the unit properly in which case it is almost certain that it is a hardware / software problem and needs to be returned. If you go this route you probably either need a new battery or if the hardware is faulty, a replacement unit.
Despite the problems you are experiencing, I have to say that the normal cycle between charges of my PRS-600 is not as long as I expected or hoped. In my case, this is about 5-8 days of steady use at about 1/2 to 1 hour per day.
Jan 09, 2011 | Sony Reader Touch PRS-600
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
Hi, Yesterday I bought haier 12000 BTU air
To determine the cost of using this air conditioner, you will need to find out what your electric company charges per kw/h. This is the standard unit that electricity is charged for. Next determine the wattage of the air conditioner. This should be found on the unit name plate. If you can not find the wattage by the name plate, the take the voltage and multiply by the amperage, this will give you watts. Next multiply the wattage by 24. (watts per hour x 24 hours) Finally divide this number by 1000. This will give you the total Kw that the unit will use in a 24 hour period. If you multiply this number by the cost per Kw that will give you the operating cost of your unit for one day.
ex. electric company charges .25/Kw The unit uses 1000 watts 1000 x 24 = 24000 watts 24000/1000 = 24 Kw 24 Kw x .25/Kw = $6.00 day
Note: all figures shown above were randomly generated in my head, and have no correlation to your calculations. Hope this helps.
May 04, 2010 | Heating & Cooling
Unit will not charge, changed battery but still does not work... Help
Sound as though you shorted something on the main board when you installed the new battery. Just sell the unit for parts on Ebay
May 03, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
21 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
