Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
No power, broke my ipod
Everything was working fine at the beginning of the day, as the day passed, I lost the function of my click wheel on my ipod. Now, my im600 won't power up. I checked the outlet and the connection to the back of product, nothing.
    Problem Solver:
  • 5 Answers
I experienced similar problems with my unit. I fixed my iPod by simply resetting it (hold on, hold off, hold the menu and centre button for about 5 secs.) My im600 seems to have some problems with the power button, but if I use the remote of just keep pressing the button till it powers on, I have no problems.
Posted on Apr 05, 2009
IPOD Classic 30GB - manual needed -I have no idea how to operate....it was a gift...used of course!
well i was able to find a user guide but it was for a 120gb ipod classic. It is the exact same functions just its a 120gb. If you can get passed that minor difference this manual will teach you everything you need to know about your ipod classic.
click here for ipod classic user manual
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Audio Players & Recorders
CLICK WHEEL IS NOT RESPONDING
Hi!
Please try resetting the ipod by pressing the center and play button on your ipod until it displays apple logo. Also try restoring it to factory settings by seeing this link from apple---
Restoring apple ipod
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Apple iPod classic MP3 Player
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
Ipod nano 3rd gen. got little water on it and the backlight won't come on. replaced to screen and still doesn't. Everything else(Syncing, audio, video, and click wheel) works fine when it is on the...
Your first attempt to turn on a washed iPod is the critical one. If you're too quick to try to power it up and the water inside shorts out the electronics, you're done. You can try waiting until the iPod is really dry and power it on again; maybe it didn't short out the first time. But chances are, if you tried once and it didn't work, the damage has been done. There are several ways to try to dry out a soaked iPod….You can put it on a widow seal that gets a lot of sun for 2 days (that is usually your best bet but…I have even heard of people who have put their soaked iPod in a ziplock bag with kitty litter in it. For a few days…..You will more then likely need to do a reset on the iPod either way…..Here is a link to do the reset http://support.apple.com/kb/HT1320?viewlocale=e...) Good Luck and please leave me a rating…..Both ways worked for me…..dang thing is just too small and I forget to check my pockets all the time…
Oct 20, 2008 | Audio Players & Recorders
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
I plugged my IPOD NANO IN TO THE COMP AND ALL **** SET LOOSE, THE IPOD ASKED FOR A RESTORE, WHICH I CARRIED OUT, I THEN EJECT AND ALLS FINE, THEN I RE ATTACH IPOD AND START INSTALLING 1 OR 2 ALBUMS TO...
As follows:
I-Pod wheel broken?
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Usb problems with 2nd generation ipod
Aug 21, 2007 | Apple iPod nano
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
341 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
