Question about HP Computers & Internet
I AM UNABLE TO PRINT FROM MY LAPTOP .I have Paper guide on HPC4100 also CD Disc for C4100 also HPPhotosmart C4100 Macintosh and on the Printer there is ( C4180)
  • 3,940 Answers
Russell
Download the driver you need from this link, and install the driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1141647&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
then the printer should work. Leave the printer disconnected from the computer until the installer tells you to connect the printer.
Posted on Jul 31, 2008
Just unpacked and installed mx870. Printer runs paper trough, print head seems to be printing, but the page is blank.
Try one or more of these solutions:
Make sure that you are using the appropriate printer driver for this product.
In Windows, make sure this product is selected as the default printer.
Check the settings on the Main menu (Windows) or in the Page Setup dialog box (Macintosh). Make sure the settings are appropriate for the paper size you are using.
Run the Head Cleaning utility to clear any clogged nozzles. See "Cleaning the Print Head" in the Quick Reference Guide.
After trying one or more of these solutions, run a printer operation check to check your results. See Running a printer operation check.
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer.
Follow these steps.
Disconnect the USB cable from your computer.
Make sure that letter-size paper is loaded in the sheet feeder.
Press the On button while also pressing the Ink button.
This product prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, this product is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with this product. For example, if bands appear in the check pattern as shown below, an ink nozzle may be clogged or the print head may be misaligned. See "Cleaning the Print Head" in the Quick Reference Guide for details on cleaning the print head.
Nov 13, 2010 | Canon PIXMA MX870 Wireless Office...
I just bought an HP Photosmart Premium e-all--in-one C410 series printer/fax/copier. The problem is, I'm unable to print photos using the photo tray. There's no option to select photo tray like my...
The problem is in your printer set up. When you go to print, select the type of paper, size, horizontal or vertical print mode. If you do not designate photo with size and paper type; it defaults to standard 8x10 paper from the lower tray. This is all explained in your printer manual or on line at HP.com.
Feb 01, 2018 | HP Photosmart C4100 series
Wireless printer
the printer needs to be connected to your wireless network.
the easiest way to do this is by running the install cd temporarily connected the usb cable and transfer the network settings
Mar 27, 2010 | HP Office Equipment & Supplies
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
HP C4100 Series Printer - Paper Feed & Print
The feed rollers might have to be cleaned or it could be a logic problem (main board) issue.
Jul 31, 2009 | HP Office Equipment & Supplies
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
Cant install my printer
Here is driver download page for your printer, insert OS version and proceed to download page:
HP Photosmart C4100 All-in-One Printer series
Aug 15, 2008 | HP Photosmart C4180 All-In-One InkJet...
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
