Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Laptop LCD Problem
Bottom 1/3 of laptop screen shows black line with everything below the line ghosted out, and I cant access that part of the screen without pushing on the left hand side of the lcd from the back and holding it until the screen comes back into view. Sometime this fix works for a couple of hours, sometimes minutes.
Also if pushing on the left side of the screen does not work than standing the laptop on its left side and applying pressure will bring the bottom third of the screen into view.
Help!!!!
  • minbody Aug 08, 2008
    I have a similar problem. The top 1/3 of the screen shows perfectly. The bottom 2/3 of the screen is messed up. Looks like horizontal lines and can't see anything behind the lines. Installed new cable. No fix. Ran diagnostics. Device: Graphics. Test: Graphics Test. Status: Error Detected! Any suggestions?
Solution please.
Posted on Aug 20, 2008
    Genius:
  • 2,028 Answers
This is most likely going to be a loose connection. You will need to take the the plastic bezel that surrounds the screen off, the screws are hidden under the small rubber bumpers. Then take the screen loose, you will see he four screws holding the screen at the sides. Tilt the screen forward and you will see the connection on the back. Make sure this connection is seated properly, you may need to apply some new tape on it if it has any. Then check any other connections while you're there. If the problem persists, then the cable may need replacing.
Posted on Jul 31, 2008
The bottom third of my screen is black w/ fine lines of colors that coincide with the current screen
Dell Inspiron 6000 are notorious for developing screen faults. Dell won't do anything about it unless under warranty. Have the screen replaced by a repair shop unless you feel confident enough to do it yourself.
Jun 09, 2009 | Dell INSPIRON 6000 CENTRINO...
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
Black screen
Try to reinstall XP again, when prompted to partiton, select to do so.
You will lose everything on the hard drive and will need to reinstall all of your programs.
Hope this helps.
Good Luck.
Nov 28, 2008 | Dell Inspiron 6000 Notebook
Lcd screen connection
You can try to reseat the LCD video connector on the motherboard. Follow these steps:
1) Remove the AC power and Battery.
2) Open the LCD display all the way flat.
3) Pry up on the notch on the right side of the keyboard bezel. This is the plastic cover that has the power button on it.
4) Unplug the LCD cable and reseat it into the connector. This is the round black cable that has a little ground screw.
If this doesn’t resolve your problem then you probably need a new LCD display panel. To replace the LCD panel you have to remove the LCD section from the laptop and disassemble the LCD plastics to get to the panel.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 6000 Notebook
Cant open laptop
Is this when you start it up, or after closing the lid and the machine being on standby?
Jun 25, 2008 | Dell Inspiron 6000 Notebook
I am using DELL Inspiron 6000 laptop.Suddenly half of the screen of my laptop is showing multi color lines. I am able to view only the upper half of the screen. Please suggest me what needs to be done
attach an external monitor to be certain the video card is ok,
next
Re-seat the video card cable to the lcd screen,
dell site explains how to remove top and keyboard.
your real issue may be the cable itself or the lcd screen.
May 06, 2008 | Computers & Internet
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 Notebook Logo
141 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
