Question about Canon PowerShot SD100 / IXUS II Digital Camera
The display is not working
I took a picture at home, got to the park and when i turned the camera on it does not work, it's like lines bouncing up and down and across the screen.
  • 3 more comments
  • Anonymous Aug 28, 2008
    I have the ixus II and it seems I have the same problem lines across the LCD and cannot take any photos not even thru the view finder very dissapointed with canon hope someone can give advice
  • Anonymous Nov 13, 2008
    I have the same problem. This was helpful though. Now I know that I can get it fixed!
  • carsh4 Dec 06, 2008
    my lcd screen has horizontal purple and black flashing ongoing lines, no picture to view. If I snap the camera, it takes apicture of the purple weird looking screen.
  • drmalooqa Jan 23, 2009
    when i click the picture seems to be finely taken ,but the final picture is black and white lines over the picture which also turns to be black &white
  • Anonymous Feb 25, 2009
    My SD 100 just started having issues with the viewing screen
See this link:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=9825&keycode=2112&id=48264
There is a problem with the CCD image sensor for the following cameras:
- Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50
- Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*), A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*), S500(*)
Malfunction:
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Posted on Nov 04, 2008
My display screen is showing pixelated noise, or completely black. When it does display, all I get are off colour, horizontal dancing lines.
Camera is defect for sure, but don't tell anyone in the service centre, because they warn you not to take a camera out in extreme cold. You should not se the camera in environments below zero degrees
I'm afraid you can't fix it yourself, and before bringing it to a Canon Certified repair centre, ask them what it could cost.
Mar 01, 2015 | Canon PowerShot G10 Digital Camera
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
WHEN CAMERA IS TURNED ON THE SCREEN WILL SHOW PAST PICTURES FINE BUT WHEN THE SELECTOR SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO THE MOVIE MODE THE DISPLAY SCREEN IS BLACK WITH LIKE PURPLISH LINES...
From your description, it sounds to me like the image sensor within the camera went bad.
This can happen from a few things:
  • Camera dropped
  • Moisture
  • Rattling around in a bag or suitcase
  • Knocking into things while in the pocket
  • Leaving it powered on in the pocket
  • Prolonged exposure to bright lights
Try taking a picture while the camera is in picture mode even if you can't see what it is of, then either review the pictures to see if what you just took shows up without issues or transfer it to your computer.
If you can see a picture afterwards when reviewing your images, then it sounds like the firmware may have gotten corrupted. In this case, you should update the cameras firmware using this LINK.
If you cannot see the image you just took, or it has those same purple lines, then it is a hardware problem and can only be fixed by replacing the camera or by sending it in for repair.
Even if you cannot see the image you just took, I would suggest going ahead with the firmware update to see if it works.
Mar 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
Display not working
if shutter is working it is the dfective CCD so replace the CCD.
Apr 03, 2010 | Kodak EasyShare C533 Digital Camera
Display has a "blotch" on it, camera not working
Sounds like a damaged LCD screen, was this camera kept in a camera case? These cameras need to be stored in a good case, they take great pictures but are somewhat fragile.
Aug 03, 2008 | Vivitar ViviCam 6330s Digital Camera
My camera
check the battery to make sure it is making good connection
Jul 23, 2008 | Olympus FE-230 Digital Camera
A85 Dead
I read something about the fuse going out...
http://www.dcresource.com/forums/archive/index.php/t-18151.html
Apr 12, 2008 | Canon PowerShot A85 Digital Camera
No display at all. But able to take pictures with Canon A75
Sounds like you might have accidentally turned the display off. Turn on the camera and press the DISP button once on the back of your camera.
Mar 17, 2008 | Canon PowerShot A75 Digital Camera
Camera repair
Time for a new Camera. It is about 150.00 to replace the LCD. it is cheaper to replace it unless you can just use the viewfinder alone!!
Nov 13, 2007 | Kodak EasyShare Z612 Digital Camera
Canon PowerShot SD100 / IXUS II Digital Camera Logo
187 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
