Question about ViewSonic VX910 19" LCD Monitor
No problem yet. just aquired ViewSonicVX910 monitar.i currently have compaq FS7600monitar. VX910 has same power connect and two others; one being DVI, the other D-SUB where as the compaq has just one other connect that seems to be somewhat permanently installed. what do i do to install the VX910 and/or is it a better enough monitar to bother? installing to compaqSR2010NX.
My monitar says no signal
Check connection that it fit to the monitor correctly.
Try other cable. Check you power source.
Oct 06, 2013 | E-Machines eMachines Monitor E15T4
The picture on my monitar has flipped over on it's side
Try holding Ctrl + Alt and pressing the Up arrow Key
Should flip back to normal
Oct 02, 2012 | Compaq Computers & Internet
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
May 18, 2009 | ViewSonic VX910 19" LCD Monitor
Cant connect laptop to internet
Hi!
I think that maybe you are using and incorrect password to connect to your wifi network.
Feb 18, 2009 | HP Compaq Evo n610c Notebook
Viewsonic vx910 19" lcd do not start
Hi...there,
It's seems you've got a busted backlight inverter...
Nov 29, 2008 | ViewSonic VX910 19" LCD Monitor
Monitar drivers
Here is general download page for your laptop, you will also need to install network driver and audio drivers :
HP Compaq nx9010 Notebook PC - Download drivers
here is video driver :
» Driver - Graphics » Driver - Graphics - Intel
Try both, as 9010 is built in two different versions.
Please vote the solution.
Many thanks.
Aug 15, 2008 | HP Compaq Business Notebook NX9010
New install of msi mainboard, no display on monitar or cd rom work
reinstall ur motherboard and cheak properly that ur mbo dont touch with earthing ( cheak ur power supply proper earthing )
Jan 05, 2008 | Intel Motherboard
Open Questions:
ViewSonic VX910 19" LCD Monitor Logo
89 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
