My suggestion would be trying to clear the dns cache. This can be a problem and is simply done with the following in command window. Make sure you start up the command window as administrator before proceeding:
At the command prompt, run the following commands in the listed order, and then check to see if that fixes your connection problem:
Check to see that the network is actually getting data. If no other machine can connect to the internet through the same network, then it's a problem at the router or the source. If other machines can connect, cut your wifi off and on again, and try again. If you've been on this network before, but now can't get anything, you might need to delete the profile for the network and re-create it -- network profiles corrupt from time to time.
I have got internet connection from my slide (EDGE). Nokia PC suite seems to offer such a connection via Bluetooth through my phone by calling it One Touch Access. Bluetooth connection is perfect, my phone alone connects to the internet but not my laptop through my phone. What needs to be done?
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Check your internet connection settings. This can happen when your netflix player can't connect to the internet. Perhaps you changed the password to your wifi connection and didn't update your player settings.
sometimes it depends on the speed of the pc or on your internet service provider or in the hub itself...try to read the specs of your hub and see how it works if it has a multiple connection...
