Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I got a F2 error code on the display. The top heating element in the oven will not turn off. I turned off the oven at the main house panel.
  • jbob67 Oct 05, 2008
    F 2 error when I left pizza tile inside during cleaning. Internal fan stays on and door stays locked. I have turned breaker off and on and left breaker off for period of time but still can't open oven.
  • 3 Answers
F2 error code oven too hot, 1. replace relay board (if present)
2. or oven temperature sensor.
Posted on Sep 09, 2008
Why is part of touch pad not working, and oven won't heat?
Hello. The part number out of the service manual for your touch panel is (white) 9756532, (black) 9756534. From the symptoms you're describing, the keypad is defective--those things are notorious for malfunctioning after a few years due to heat. The error code you got is definitely for a shorted keypad. UNPLUG THE UNIT FIRST. Then, carefully unplug and re-plug the connector on the ribbon from the main board a few times--this will re-scratch the metal pins( they will oxidize over time and break contact)--try this first, if it doesn't work, replace the keypad. Now, when you took the control panel loose, you might have pulled a wire loose from the main oven control board--it's easy to do. Go back and re-check the wires carefully. Here are some pix of the electronic schematic diagram for your range:
Notice in the 3rd pic P2-1 and P2-4 which are BLUE AND RED WIRES, RESPECTIVELY. Look on the oven control board for connector 1 is for BROIL and pin 4 is for BAKE. Also, make note of the wire connections on the left side of pic 2--a black wire powering the other side of both the bake and broil circuit. Also, mounted on the rear of your oven, is a thermal fuse, part number 3196548. (note: right side of pic 3, labeled non-resettable thermal fuse) It is a round device, about the size of a half-dollar, with 2 wires connected to it, blue wire with a white stripe, and a red wire. If that sensor is opened, it kills the power to the elements for safety. (And is what trips when people use the self-clean feature)
For those that aren't familiar with how ovens operate:
Whenever an oven is plugged in, 120v is present on the bake and broil elements. When you turn on either one, the main board simply connects the other side, not to ground as in most other devices, but to another 120v on the opposite electrical phase **adding up to 240v** and heating the elements!!
This is why it's so important to **always remove power** before attempting to service an oven or range.
I hope I helped you!
Sep 20, 2015 | KitchenAid KERI203PBS Electric Kitchen...
Whirlpool gy396lxpso2
You will need to replace the control panel.
Here is the part to order.
Oct 19, 2013 | Kitchen Ranges
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
I have a Kenmore oven, F2 error, not heating, fan not running!
Looking up your fault code and this is what I found :
replace oven control (also called clock or ERC). It's the temp control unit for the oven, this could explain your lack of heat.
Jul 20, 2009 | Kitchen Ranges
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
229 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
