Question about Toshiba 50H71 50" Rear Projection Television
Picture distortion When I turn on the set the picture is distorted for several minutes then evens out.
I have the same or similar problem.
Only HD1 and 2 inputs work correctly.
Posted on Mar 22, 2009
I replaced both backlight boards but still having problem with LCD is too dark and color distortion.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 05, 2015 | LG 42LC2D 42 in. LCD HDTV
My sony wega kf-50we610 unlike every one else i have no problems with set turning on my problem is i cant watch anything do to the picture being distorted scrambled like i can see the menu options and...
It looks like the vidoe board but the fault can be also a distortion in the horizontal / vertical section. So check the PIN amp and related sections. What must be looked is of the HSTAT can be off set.
Deguass the set well to confirm if there is any possibility of a distortion of picture by a severe magnetic field.
Since there can many problems associated with a distorted picture but you can try and see these possibilites other than the Y amp processing. Hope my suggestions helps.
Aug 20, 2010 | Televison & Video
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link..
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Toshiba 50H71 50" Rear Projection Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
