If you use the same sim card, this PUK will still be there. You must contact your provider for the puk code. If you still have "attempts" remaining you can save the sim card. If it says PUK Locked...then u need a new sim card.
The PUK (Personal Unblocking Key) and PUK2 are used to unlock the PIN and PIN 2 codes respectively if your SIM card is blocked. It means that the problem here is your sim card and not your phone. You don't need to get a new phone just replace your sim card.
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
A PUK (PIN Unlock Key) code is required to unlock
SIM cards that have become locked following three successive incorrect
PIN entries. If your SIM card becomes locked, you will need to get a PUK
code from AT&T to unlock your SIM card.
You can obtain your phone's PUK code from AT&T in one of these ways:
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
