Question about HP LaserJet 2300N Printer
It runs but blank pages come out
We recently moved printers around in our office. This one, which has always been the workhorse, was missing a toner cartridge for a while. It's been replaced and the printer runs when we send documents to it but the pages come out blank. It says the cartridge is installed correctly. We took it out, checked it and put it back in. Still nothing.
  • jmarino Jul 31, 2008
    Thanks for the suggestion. I checked it - there is nothing loose in the path. It does not appear to be a quick, easy fix. I am going to turn the problem over to the office manager, who has more resources than I do. Plus, he's the one who's got the authority to do something about it.
  • Tim Babcock
    Tim Babcock May 11, 2010
    It could be the transfer roller got out of position when it was moved. If you take the cartridge out, see if there are any loose parts in the path
The problem you will have is that you have not removed a tag on the Toner cartridge. Several of my technicians have done the same thing and caused the exact same issue.
It will be a black tab with a silver plastic strip attached which stops the cartridge releasing toner.
Hope this helps
Posted on Jan 05, 2009
  • HP Master
  • 2,794 Answers
It's gets to be messy at this point. It probably requires a technician to troubleshoot it futher at the office site.
Posted on Jul 31, 2008
My printer brother HL2170W has toner, the toner light is not flashing but whet its prints it comes blank
This sounds like an issue with either the toner cartridge or the drum unit. Have either of these consumables been changed recently? This should help identify the likely cause.
If the drum has been changed recently I would recommend cleaning the corona wire. If however the toner has been changed there isn't masses I can recommend in terms of trouble shooting. it may however be worth running off 15-30 pages in the hope of pulling the toner through.
Failing this I would recommend calling Brother technical support in case the issue is hardware related and not the fault of a consumable.
Oct 31, 2012 | Brother Office Equipment & Supplies
HP LaserJet 4250n Printer all pages blank even with new toner
Have a service tech check for the presence of the hi voltage applied to the paper to attract the toner.
Mar 10, 2017 | HP LaserJet 4250n Printer
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
The printer runs properly but will not print; A blank page cycles
It is not the toner. There are 2 things you can try yourself, anything else requires service. First try opeing and closing the right hand side door. Try this several times if necessary. There are contacts in this door that sometimes don't make contact and opening/closing the door will sometimes resolve blank copies. The other thing you can try is remove the toner then pull out and reseat the drum unit. Here again there are contacts that need to be made that can cause blank copies.
Good Luck and Thank You for using Fixya.
Apr 09, 2010 | Sharp AL 1631 Copier
Vertical blank "line" on printed material.
try the toner cartridge. You can see where its coming from by printing 1 page. When the page starts coming out of the machine open the cover. Take out the toner cartridge and look at the page. The line should be there and you should be able to figure whats causing it. It's almost always the toner cartridge. If you have an old cartridge put it in and run a test with it. If the line is gone its the cartridge. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 1100 Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
Printing blank pages from word and now every time canon 6530
There is a service update from Canon, where a part needs to be change in the laser area. You can try to slam the toner door shut to see if it changes it temporarily, but a laser shutter arm needs to be changed.
Mar 25, 2009 | Canon MF-6530RF Factory Reconditioned...
HP LaserJet 2300N Printer Logo
52 people viewed this question
Ben Johnson
