Question about JVC RV-B90 Boombox
Remote control I have no remote and cannot pre-set radio
  • nojo10 Jul 31, 2008
    can anyone tell me how to set pre-set radio stations without a remote on a jvc RV-B90GY
  • 752 Answers
It appears you MUST have the remote. It's on page 27 of the manual:
http://books.jvcservice.com/Download/932445795/VNN5219-253N.pdf
Posted on Aug 04, 2008
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
I need the codes for panasonic
The 15-2147 is pre-programmed with the following codes for Panasonic TVs:
0250, 0051, 1919, 1941, 1927, 1924, 1946
If you need codes for devices other than TV or programming instructions, please post back including details of the devices you need codes for.
Please note that if your TV is newer than the remote, these codes may only control basic functions or may not work at all. Not all universal remotes will work with all devices.
Regards,
BElectric
Nov 20, 2010 | Radio Shack (15-2147) Remote Control
Double image
it is not majer problum. this is a convergence problum pls read user"s menual and set convergence seting on the remot control.
if not posibal convergence seting then inside the fornt cover 6 pre-set Adjesting 3 pre-set on top is foucas Adjment.
and 3 pre-set bouttom is screen Adjesment for R_G_B. Gun. set perfact Adjestment.
Oct 04, 2009 | Samsung Televison & Video
Radio goes into search mode when selecting pre-set stations
it is merely making the exact set connection
Aug 27, 2009 | 2006 Volvo S60
Radio and clock will not work. The fuses are good i think.
Check fuses first. please rate as fixed if this solves you rissue. report back results.
VISUAL INSPECTION CHART
Mechanical Electrical
  • Integrated control panel with or without tape player physically damaged, misaligned, any controls inoperative.
  • Digital audio compact disc player physically damaged, misaligned, any controls inoperative.
  • Radio antenna lead in cable, electric antenna or bodyphysically damaged or misaligned connections.
  • Radio speaker mounting/speaker cones physically damaged, misaligned.
  • Radio ignition interference capacitor or radio frequency interference suppression bond misaligned, unclean and no metal-to-metal contact.
  • Mobile telephone transceiver; mobile telephone handset, mobile telephone microphone, mobile telephone transceiver holder cradle physically damaged, misaligned.
  • Open fuses: fuse junction panel fuses 8 (5A), 12 (5A), 20 (5A), 22 (5A), 24 (5A) or power distribution box fuse 17 (20A).
  • Open connectors.
  • Corroded connectors.
Section 15-00: Audio Systems—Service 1999 Taurus, Sable Workshop Manual DIAGNOSIS AND TESTING Inspection and Verification NOTE: Many customers do not understand the limitations of FM reception. Refer the customer to the Owner Guide for information about the limitations of FM radio performance.
Internal diagnostic examination of the integrated control panel, rear chassis unit and audio compact disc player should be left to the authorized radio service center. However, the automotive technician should be able to analyze and isolate radio reception conditions to the proper area or component causing the condition. All radio conditions can be isolated to one of six general areas:
  • antenna system
  • integrated control unit
  • radio speaker system
  • radio noise suppression equipment
  • rear chassis unit
  • audio communications protocol network
Retrieving Diagnostic Trouble Codes (DTCs)
Using Audio System On-Board Diagnostics
The audio system has on-board diagnostic capabilities and is equipped to check for every component available in the system even if this specific vehicle is not equipped with all components. A Diagnostic Trouble Code (DTC) will be set for the missing components. These DTCs can be ignored if the vehicle is not equipped with these components. The battery must be fully charged for proper audio system operation. The ignition switch must be in the RUN or ACC position. Turn the system on, tune in a strong AM station and verify good reception. After an AM station is checked, tune in a strong FM station. The system is now ready to enter the diagnostic mode. Diagnostic Mode:
NOTE: Battery must be fully charged for proper audio system operation and self-test.
Enter Diagnostics mode by pressing SEEK DOWN button first and then pre-set button 3. Hold both buttons for five seconds. This will suspend all normal radio functions, retain the previously selected frequency and display DIAG.
  1. NOTE: To perform diagnostics, press the appropriate buttons as instructed.
    SYSTEM CONFIGURATION SELF-TEST:
    Press pre-set button 1. This will check for connection of all possible devices and log the diagnostic trouble codes for any device that does not respond. The display will flash SELF while gathering the diagnostic trouble codes, then stop flashing when complete. To exit System Configuration Self-test, press pre-set button 1 again. To retrieve diagnostic trouble codes, press the TUNE UP button. This will display the diagnostic trouble codes if any exist. Continued pressing of the TUNE UP button will display the next diagnostic trouble code. Record codes and refer to the following table. To exit the Retrieval Mode, press pre-set button 1.
    CONFIGURATION SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit 2 No response from tape deck 3 No response from bezel microprocessor 4 No response from compact disc player 5 No response from steering wheel controls 6 No response from rear seat control 7 No response from remote climate control 8 No response from navigation module 9 Read Only Memory verification failed
    Remember, system configuration will test for all possible equipment connections. Inspect the vehicle to determine actual equipment installed.
  1. Integrated control panel display test:
    To enter the integrated control panel display test, press pre-set button 5. This check will light all segments in the integrated control panel. The system will automatically exit this test after five seconds.
  1. Integrated control panel and rear chassis unit identification:
    To enter this test, press pre-set button 3. This test identifies the software level of the integrated control panel and rear chassis unit. The integrated control panel is tested first, followed by the rear chassis unit. The completed test will exit automatically. For code identification, refer to the following table. The display will have two sequences of five codes each. The first sequence is for the integrated control panel, the second sequence is for the rear chassis unit.
    Item Part Number Description 1 — Product Type Code 2 — Product Variant Code 3 — Software Version Level 4 — Software Version Release 5 — Software Version Patch
Apr 23, 2009 | 1999 Ford Taurus
I have a Zenith Clock Radio Model#Z213B Serial#ZRS04952730 that i bought at a Thrift store. My question is,did this radio originally came with a remote? I`ve noticed there`s a small window on the front of...
Yes - I have it too - - - - and it has a remote (though one of the buttons on it doesn't work) When I get home I'll find out more.
Question for you - - - - I had power outage recently and lost the radio presets. (And I can't find the manual). Do you know how to set the radio pre-set buttons??
Apr 08, 2008 | Audio Players & Recorders
JVC RV-B90 Boombox Logo
178 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
