Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Staple i'm getting the message "remove paper from inner tray of finisher" when i try to staple. Please help. darlene.jones@gscs.org
  • m13d4j10 Jul 31, 2008
    I had already tried the power. I will contact a tech. thanks.
  • Kyocera Mita Master
  • 2,794 Answers
Turn the power off. Wait 30 seconds and turn the power back on again. See if there any error codes that pop up on the screen. If there isn't any, the stapler might have returned to the correct position and should work fine now.
If it continues a technician should inspect your finisher section in case the staper section needs to be repaired.
Posted on Jul 31, 2008
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
Jam - remove paper from inner tray
open the finisher(sorter) door and pull out the inner tray. Remove paper
Apr 06, 2010 | Kyocera Ai3010 Copier
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
I need to change staples
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
Paper jam
Please try remove the staple cartridge (the copier power on),if is not posible you need diassambly the finisher stapler unit.
Aug 19, 2009 | Xerox Office Equipment & Supplies
Cannot print a manal with the finished size as 5.5x8.5 folded and stapled. IT SHOUD PICK UP THE 8.5X11 PAPER AND FOLD AND STAPE IT BUT IT DOESN'T. Please HELP.
for the 8.5x11 paper to staple the paper has to loaded in the machine with the short edge of the paper fed first so if the paper is turned the wrong way in the paper tray the machine will reject the fold command it should say on the paper type setting 8.5x11R
Jul 21, 2009 | Konica Minolta Office Equipment & Supplies
Replacing the Staples
The copier will inform you when it's out of Staples. To check the staples, open front cover of the finisher (device on left that catches copies) There should be a pictorial diagram on how to remove/install cartridge on inside surface of cover. Page 7-12 of the Copier Reference Guide if your finisher has 3 trays. Page 7-38 of the Copier Reference Guide if your finisher has 1 tray. Hope this helps.
Jun 18, 2009 | Canon imageRUNNER 400S Copier
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
117 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
