Question about HP ScanJet 8270 Flatbed Scanner
Scanner scan but then locks up at the end
My new HP Scanjet 8270 scans nicely, but then at the end of the scan it locks up and makes an odd knocking noise. The only way to stop the noise is to unplug the scanner. The software freezes up too. I've tried loading the drivers on 3 different WinXP Pro SP2 machines, and it acts the same way on all of them.
I tried scanning from the glass and from the ADF feeder... same result. It scans and then locks up and begins a light knocking noise.
Any ideas?
Paper Jam - as i was scannin my work papers, it got jammed. i gently pulled it out and it ripped, some bits of pieces from the paper is inside the scanner; i tried to remove it but couldnt. it may as well...
Unless you get all of the paper particles out of the intake rollers and gears, you will have existing problems. The speed and motion is effected and there are tiny activation switches that tell the scanner light to make a pass and when to stop. If you cannot clean out left over debris then have a technician do it for you.
Jan 12, 2018 | HP ScanJet 8270 Flatbed Scanner
Tip
Windows 7 and HP scanjet 8250, 8200, 8270; front panel buttons and searchable...
How to install a HP scanjet 8250 in windows 7 with full features like double side scans and searchable PDF creator.
The basic driver automatically installs with windows 7.
The basic driver lets you scan one page at a time and does not let you do advanced options like double side and creating searchable PDF's.
HP has a software package listed for the HP 8270 scanjet that works properly with the 8250 scanner. I would assume that any scanner in the 8200 series would work with this software.
For full scanning features, I installed the HP photoshop essentials and the HP solution center. Find the download here, on HP's web site.... http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1118286&prodTypeId=15179&prodSeriesId=1118292&swLang=8&taskId=135&swEnvOID=4062
Click on the software link .."HP scanjet Full Feature Software and Driver"
After the install run the setup and follow the directions,
After the install, the front panel buttons on the scanner should now work. You should also be able to create PDF's(searchable) with the one touch of the scanner button.
on Jan 28, 2010 | Computers & Internet
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
HP 8270 does not scan on windows Vista . Could not complete scan is the error message
Make sure you have the newest vista drivers located here - also, make sure that the scanner platen is travelling the full length of the scanner, it's not being hung up somewhere causing it to jam. Try to scan while the cover is open to watch the scanner head travel.
Oct 21, 2009 | HP ScanJet 8270 Flatbed Scanner
Pages scanned are backwards (read right to left and all letters are backwards...as if holding up to the light and trying to read from the backside)
Pls check if the 'mirror' option is on in the software setting. The scanner 'reads' normal way always.
S. Mohan
Jul 14, 2009 | HP ScanJet 8270 Flatbed Scanner
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
HP ScanJet 8270 Flatbed Scanner Logo
333 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
