Question about LG Washing Machines
I own a LG WD-1019BD front loader. It won't work after resetting a circuit breaker in my electrical box outside the house. Nothing at all when plugged in and turned on. Not even a hint that power is present even after changing power outlet to another room. It was working fine until the c/b tripped.
3 Suggested Answers
SOURCE: My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Posted on Jun 30, 2009
  • 49 Answers
SOURCE: kenmore elite calypso wash motion top loader won t
Unplug the unit and let it sit unplugged for 30 minutes. There is a power filter on the AC input line and sometimes power surges can cause it to need to bleed off the voltage from capacitors. There is a test procedure to see if the filter needs to be replaced but so far every time this has happened to our Calpyso, we pull the plug for a bit and the washer recovers.
There isn't enough space on this text box to post the removal & replacement procedure for the line filter, but you can find it at www.pcappliancerepair.com and look up the part # on the Sears Parts Direct site for your model # specifically.
Posted on Oct 03, 2009
Wiring diagram for kg80490np washing machine front loader
More details required. i.e kg? np? Brand name enter minimum details in Search box should show up and suggest.
Good Luck
Feb 03, 2015 | LG Washing Machines
Hi, my name is Sandra I was watering my plant outside and it is right next to an out lid plug by the front door. well it got wet and now my moms master bathroom lights won't work but the rest of...
Quite possible that water which has gone in side the plug has caused a short circuit. Let it get dried up. Blow some air in it. Next to the breaker there must be a distribution box where individual fuses are there. Check them individually. You will find the one which has blown up.
Jun 08, 2011 | Computers & Internet
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
How to replace bearings on LG WD-1019BD washer?
To get to the bearings you need to remove the rotor as you have done, remove the front, you need to push a card under the lip of the top at the front to open the top to get out the front. Then then you need to undo all the bolts in the middle of the tub, then take out the inner drum and then you can hit the bearings out with a drift, Don't just replace the bearings, you also need to replace the seal and spider which is the 3 legged part with the main shaft on it, otherwise if you don't replace all the parts listed it will not last long before the same happens again. The problem is caused by the seal letting watter into the bearings, the new seals are mdified to help stop this happening.
Apr 12, 2009 | Washing Machines
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
May 22, 2006 | Fisher and Paykel (IWL12)
Washing Machines Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
