Air conditioning Good morning: My Colemant heater/air blower fan will come on real slow with the air on (haven't tried it with the heat since it's 100 degrees where Im at). Anyway it will run for about 3 minutes, starts making a howling noise and then shut off. After sitting about 5 minutes it will come back on but continue to cycle as I've mentioned. Sounds to me like the bearings are bad and starts to seize up and a relay shuts it off. Are there lubricating spots on the motor ? I know it's a fairly older unit, maybe time for a new motor ? Any people in my area you know that is fair I can contact ? Thanks so much, Ron/Yucca Valley Ca.
  • 1,420 Answers
You will need a new blower motor, sorry.
Posted on Aug 07, 2008
Why is fan control stuck on 4?
A mechanical fan/blower control that's stuck on 4 is a worn/faulty switch. The blower motor fuse could be blown or the blower motor is dead. A electronic fan/blower control that's stuck on 4 with no blower could be a blown fuse in your fuse box, the blower motor is dead or the climate control reading itself could be sending a false reading or the unit tself iis faulty.
Sep 18, 2015 | Subaru Impreza Cars & Trucks
Heater fan is not blowing any air in my 2010 Q5
Check fuses, relay, or fan motor itself. Some vehichles have a blower motor resistor usually located right near yhe blower motor.
Mar 04, 2014 | Air Conditioning and Heat for Audi Q5
Heater not working in extreme cold weather because fan wont shut off. fan has been replace and the computer has been checked. nobody knows what is wrong
I'm making some assumptions, here.. I've been told I make too many assumptions... but, I'm assuming that you're talking about the engine cooling fan.. If I'm correct in this assumption, my guess is that you've not taken the vehicle to a good, reputable mechanic or repair shop. There are several reasons that an engine fan would not turn off, and each reason would have to come from a qualified mechanic. For example, there is a sending unit for the air conditioning system that might cause continuous running... or a sending unit in the air conditioning system that could cause the same thing. To complicate that issue, quite likely your air conditioning system purposely kicks on the engine fan any time you run your defroster. Also, your inside heater should function correctly, regardless of the engine fan running continuously. If I'm wrong on that score, then your engine has a thermostat problem "to boot"... which, by itself, could cause poor heating of the inside of the vehicle. NOW, backing up a little, if you so happen to be talking about the fan INSIDE the vehicle that is part of your heating OR air conditioning, we have a little different matter on our hands... First, some vehicles legitimately have a fan running on slow speed at ALL times.. for continuous air circulation purposes (sometimes, you can't actually hear this). Also, I might add that THIS fan running all the time should not be a problem for the heater to work properly.
Jan 03, 2014 | Cars & Trucks
No heat blowing cold air.
Do you smell coolant inside of the vehicle. If so then chances are your heater core is going.
Nov 23, 2013 | 1997 Ford Contour
The heater in my 1991 wrangler doesnt give out warm air. No real heat
probably have a blockage in the heater core or heater hoses to the core
Nov 24, 2011 | 1991 Jeep Wrangler
FAN OF A JAGUAR S-TYPE 2000 HAS ONLY ONE SLOW
check the blowermotor resistor, this is what controls the blower speed and is a very common problem.try replacing the resistor, that should solve your problem. good luck.
Mar 02, 2010 | 2000 Jaguar S-Type
How can I fix my air conditioning?
you need to replace the blower motor, Im not %100 on the location of the one in a 97 pontiac mini van, but they are generally located just above the floorboard, under the dash on the passenger side of the vehicle.
GOOD LUCK
Jul 17, 2009 | 1997 Pontiac Trans Sport
Air conditioning and heating controls
heater is unpleged cheak with car heater is pulged are unpleged
Jun 06, 2008 | 2002 GMC Sierra
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
