Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Ice maker stopped working
I replaced the water filter and now my ice maker stopped working. Water on door is fine. Looks like ice maker is not getting any water.
  • Anonymous Mar 15, 2014
    kenmore ice maker not getting water
  • 3 Answers
I just had the same problem. You need to purchase a new motor module part numnber #8021515. I purchased mine at a Sears Service Center for 77.59. I installed it yesterday and again now have ice. Took about 10 mintutes to install. The tricky little part is removing the old one. Unscrew the three screws, and there is a white tab that needs to be pressed together (use tweezers) to remove the unit from the shut off arm.
Posted on Aug 03, 2008
2 Suggested Answers
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker has stopped working. Put in new filter but still no ice. Water dispenser is fine but water will not go into ice maker to make ice. Please advise.
The ice maker has its own valve which is the same part as the water in the door with its own valve as well , replace the dual valve for the fix. It is located where the water line connects.
Phil
Apr 11, 2009 | Refrigerators
Ice maker been working fine, just stopped?
If no ice is being made at all it is probably one of three problems. The ice maker itself needs replacing. The water inlet valve needs replacing. Or the freezer is not 10 degrees or less. You will need to test the water valve solenoids. If you have water in the door then there will be two solenoids. One for the ice maker water and one for the water in the door. They are both mounted on the same assembly. The easiest way for you to test is with a meter. You want to check for continuity on the solenoid for the ice maker. If no continuity, it is bad. If you have both water in the door and ice maker and no meter you can swap the two quick disconnects on the two solenoids and then see if you still get water from the door by now using the other solenoid. If you do not, then you know that, that solenoid is bad. If the soloind is good then you probably have a bad ice maker not calling the ice maker fill valve to allow water.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
