Question about Apple iPod nano
IPod not charging
The screen is saying "Low Battery. No battery power remains. Please connect iPod to power." I'm connecting the iPod to my computer using the cable but its not registering the connection and the iPod isn't recharging.
  • 4 more comments
  • tbifero Mar 10, 2009
    iPod not charging.
    computer does not recognize when I plug it in.
  • Anonymous Mar 28, 2009
    i kept for charging screen showing low battery and coputer doesn't recognize it
  • Anonymous Apr 08, 2009
    I even went and got a brandnew cord
  • jonathon Sep 03, 2013
    my i pods not chargind i pluged it into my charger and it didnt charge and then i restarted my i pod and then i pluged it into my computer and it still wasnt charging
    my i pod not charging what do i do?
    my i pod is not charging what do i do
    Master:
  • 623 Answers
Your cable might be worn out
Posted on Jul 31, 2008
Wont turn on after reset
The iPod Touch has a battery capable of up to 40 hours of audio playback, but depending on how you use your iPod, the battery capacity can vary widely. If you attempt to turn your iPod on and get no result, the battery could be fully drained, which you can easily resolve by connecting it to your computer to recharge it. If this doesn't work, resetting or restoring your iPod may get it working once again.
Charge Connect your iPod Touch to your computer using the USB cable that came with it and charge it for at least 10 minutes before attempting to use it again. If the battery is fully drained, the screen may remain blank for a few minutes after plugging it in, and then a low battery image will appear, indicating that you shouldn't unplug it for at least 10 minutes. Never plug your iPod into your keyboard, but rather into the computer itself. Also make sure your computer is on and not in sleep mode while your iPod is charging, or the battery may drain rather than charge. Reset b> If recharging your iPod doesn't resolve the issue, reset it while it remains connected to your computer. Push the "Sleep/Wake" button and the "Home" button simultaneously until the battery symbol or the Apple logo appears. This takes about 10 seconds. Continue to charge your iPod if the low battery image appears after the reset. Restore b> If your iPod Touch still isn't responding, restore it in recovery mode. First, place your iPod in recovery mode by disconnecting it from the USB cable, and then press and hold the "Home" and "Sleep/Wake" buttons simultaneously until the iPod turns off. Push the "Home" button once again, and continue to hold it while you re-connect your iPod to your computer using the USB cable. Continue holding the "Home" button while the iPod turns on and release it only when the "Connect to iTunes" screen appears. Open iTunes, and click "OK" when the recovery mode alert appears. ITunes will restore your iPod back to factory settings. You'll be able to sync it with iTunes to recover the data you lost during the restore, provided you have synced with iTunes in the recent past. Check Liquid Contact Indicators b> All iPods manufactured since 2006 have built-in liquid contact indicators. If your iPod has been in contact with liquid, this could be the source of your problem. You can check whether the liquid contact indicators have been triggered by looking straight down the headphone jack on your iPod. If you see red or pink at the bottom of the headphone jack, your iPod has been in contact with liquid, and this is likely the cause of its malfunction. Contact an authorized Apple repair center to inquire about whether a repair is possible. Such repairs aren't covered under your iPod's warranty. iPod touch: Hardware troubleshooting http://support.apple.com/kb/ts2771 iOS: Unable to update or restore http://support.apple.com/kb/HT1808
Apr 13, 2013 | Apple iPod touch
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Ipod says charged, but when i unplug it it cuts
  1. First thing to do is restore it to factory settings to see if that corrects the problem.
  2. Make sure you’ve installed the latest version of iTunes.
  3. Open iTunes, and then connect your iPod to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod in the Source pane and you will see information about it appear in the Summary tab of the main iTunes window.
  6. Click the Restore button. A window will appear asking "Are you sure you want to restore the iPod "iPod" to its factory settings? All of your songs and other data will be erased."
  7. Click Restore again. (If you're on a Mac, you'll then need to type in your password.)
  8. During stage 1 of the restore, a progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If all else fails and the battery is bad, replace the battery. Here is a video that will show you just how easy it is. No need to pay Apple any more money than you already did to repair it.
http://www.youtube.com/watch?v=2h53otOBTsI
I hope this helps and good luck!
Nov 03, 2009 | Apple iPod MA446LL/A MP3 Player
Battery depletes over night after fully charged with no use
This is because the cable that connects new battery to iPod is either damaged, or has come loose...
Take it back to whoever performed the replacement... Or, I can walk you through the repair myself, but you will need a VERY thin flat-head screwdriver (like the kind in glasses repair kits).
P.S I GUARANTEE this is your solution... I'd stake my iPod on it.
Apr 23, 2009 | Apple iPod MP3 Player
When plugged into my computer ipod screen says low battery, connect to power
Make sure the hold/lock switch has not been activated - it will prevent proper charging.
Mar 26, 2009 | Apple iPod nano
Ipod not charging
it may be possible that your itunes does not recognize your player becauseno power remains in the battery. try charging your player loner or if it doesn't work that way, have the battery changed
Mar 10, 2009 | Apple iPod nano
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Froze/no charge
It has a very low batteyr voltage therefor your computer cant charge it. Buy a wall charger but you may have to put it on disk mode.
Jan 11, 2007 | Apple iPod mini 2nd generation MP3 Player
Apple iPod nano Logo
204 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
